Alexus - A 2000 LX470 build thread (4 Viewers)
Vacaville, Ca
I will start by saying thank you to everyone on here. Past and present. I bought my 470 in February and thought I was way in over my head. If it wasn’t for this forum, I do not think I would be happy with my purchase like I am now.
My 2000 LX470 came with just over 188,000 miles. It is in good condition. I had to do some major upgrades to bring it back to stock when I bought it:
• OEM Steering rack
• CV Axles
• OEM Exhaust manifolds
• OEM power steering pump with complete fluid flush
• OEM serpentine belt.
• Oil dipstick o-ring
• Ignition cam shaft replacement
• And I am trying to find a place I trust to replace the windshield that cracked when I got cold water on the glass during a 100 degree day. Totally my fault because the windshield was already chipped.
These were done in the first 2.5 months of ownership, and I was pretty deflated. I am also chasing down a very intermittent starting issue.
I am finally in a place where I have been driving it for about 6 weeks with no issues. I took it on my first overnight trip to Mendocino National Forest last week with my daughter. It was stock and I could not have been happier with the quality of ride, comfort, and capability.
I have been pretty motivated by all the build threads on here and I have always wanted to do my own. Maybe help someone along the way and also keep a good record of my progress so I don’t forget. I just 40 this year and I already know my memory is going….I think. Haha.
I have another trip planned at the beginning of August. Between now and then I will be flushing the coolant, installing new coolant hose 1 and 2, and putting in new coolant. I have the hoses already and will find time in the next week or two. My other short-term goals are new wheels and tires. I already have the FN 5-star wheels in gunmetal gray sitting in my garage. I am deciding between 295s and 315s Falken Wildpeaks. Not sure which way to lean. I also want to put on a 1.5 - 2-inch suspension lift. I am leaning towards the Ironman 4x4 foam cell kit. I know the AHC debate is real. This is the best decision for me and what I want.
I find myself on this forum once a day just checking in to see what things people are talking about. Looking forward to posting more about this new addiction.
My two children kindly took the liberty of naming the truck "Alexus". So I will name the build thread in accordance with their decision!
Had a free hour today after yard work so I decided to do the “insta-lift”. Initially I decided to wait on removing the floor boards until I had the new wheels and tires on. But I felt good after yard work and decided to get it done. Lots of good videos online helped me through it. Took about 1 hour. Driver side way easier than the passenger side. The front support on the passenger side was blocked by a couple hoses. I had to remove the hose shield and the hose brackets so I could get my 13mm socket on the front bolt that holds the support to the front passenger area.
Before:
After:
Definitely happy with the “look”. After pouring over these threads I’m pretty set on getting 295’s on my new FN wheels. Until then my hunger is satisfied with the floor boards removal.
I just came back inside after taking off the first pressure clamp for the heater T. I planned on replacing the Ts today. It looked like (to my 40yearold eyes) that green coolant came out. The radiator and overflow have looked red since I got it. And no one has touched the coolant. I’ve owned it since Feb this year. So I stopped and decided I need to do an entire flush. Why not. I haven’t done it yet, I need to replace the T’s and I have a new hose 1 and 2 with new pressure clamps. So I’ll start draining the coolant this week, flush it with distilled water until it’s clean, then fill it back up with fresh red.
Yeah. I'll be using this video to help me through it. This guy has great videos. I should be able to drain all the fluid today or tomorrow. Then I will flush with distilled water until its clean, then ill pump in the concentrate and 50/50 mix. . New heater t, new up and down coolant hoses and clamps.
You mentioned a starting issue. Are you getting the random “click” but no start from the starter? If so, that is exactly what mine was doing. It would progressively get worse at the most random times. Then it eventually just failed. If that’s it, it’s time for a starter.
I actually have not had any start issues since my last post on that which was June 15th. I hope this doesn’t jinx it! Haha
I had to go out and start it to make sure the mention of the problem didn’t start a cascading jinx situation. Haha. It started no problem. I got a good PM from a member telling me to make sure I hear the secure lock sound when I leave the car. He explained that if I didn’t, one of the locks might be stuck in a position that is causing a small electrical draw that kick in that funky start situation. I found that my driver door lock doesn’t lock great but unlocks fine. So I made it a point to make sure I manually lock my driver door when I get out of the car. There is a cool fix I found on YouTube that involved fixing the locking motor. Right now I’m focused on replacing the coolant and the heater hoses. It’s something I’m willing to live with until the more major projects are completed.
I put on Lamin-x amber film on my fog lights. $21 and got to my door in about a week. The fog lights popped out after removing 3 nuts and disconnecting the lights. I gave the lenses a good wiper down and pressed on the film. Went on easy but it wasn’t exactly the shape of the light.
This had nothing to do with function and everything to do with looks. Haha.
I started my coolant flush next. Started draining the radiator and put on the new upper coolant hose with new pressure clamps.all new coolant hoses and heater tees going on.
