I didn't want to hi-jack a thread, so I'm starting a new one: I'm under the impression that my 80 has an alarm clock... how do you use it? I tried searching but got nothin.
Cruisin'Carolina said:My 94 has an alarm clock, I believe.....would have to go check, just remember thinking hmmm.....
LX_TREME said:RT, off the topic but check out the gauge oil temp on the top left side...thats pretty high...hope the gauge wrong..
alaskacruiser said:Wow- yet another item changed from the 93-94 to the 95-97 model years. Must've been more cost-cutting.![]()
The first pic you posted (not the second one thou) oh well..i didnt know that wasRavenTai said:On the 95? I am not aware of any oil temp gage from the factory. I think you may have misstated.
I can’t see the water temp needle, the oil pressure gage looks about where mine goes to when at cold idle, maybe it is a needle width higher.
Maybe cost cutting, maybe due to the space available in the new dash, loots narrower and taller on the 95 than in the 94,
Yep sorry nevermind.. didnt thought about it ( first crank, thought the engine idle for long period time) back to topic alarm clock..Bear80 said:You mean oil pressure, and mine runs right up to that or past it on the first crank, no matter what the temp is outside. 15w-50 mobil 1.
Bear80 said:Both pictures are from EBAY, none are RavenTais'. I'm sure that 95 was just cranked befor the picture was taken.
ultimauk said:Raven,
Your word is as good as gold on this forum,
but "the oil pressure gage looks about where mine goes to when at cold idle," your oil pressure is above 3/4 at idle?
I have 300k on mine and it sits at 1/4 (on a good day) when cold at idle with 15w-40.
I assume by other posts 1/4 was normal, but then again maybe my memory isn't up to snuff?!?
If you don't mind can you confirm?
