Builds AK HJ-75 (1 Viewer)
It was worse before I know the source of the noise.
Now I know the springs and tie rods are not falling off.
Very sad that parabolics are not made for MWB.
One of the rear bush holders had some corrosion inside, wondered why that one bush had a hard time coming out. Chipped, ground as much of the rough stuff off I could.
Test drive on the snow/ice packed neighborhood roads with pot holes in the ice. First impressions are that it hits the holes softer than before. So, so far good results. Will take time to see how else it behaves at speed on the road and off.
Hello,
Are TT leaf springs lighter than Dobinsons? Just curious.
Juan
Nice work mate! How much were the parabolics before shipping if you don't mind me ask? Read mixed reviews about them, but they are elegant.
Personally I have had far greater longevity from poly bushes and water does not hold in the eyelets like rubber holds it, it is a very rust prone area even if smeared with rubber grease. I don't mind the vibes, the dirt tracks are full on corrugated I go on anyway.
After seeing my neighbor's Bilstein shock fail on his lifted 4Runner, my vote is for the Terrain Tamer.
To elaborate on the failure; the shock rod unthreaded itself from the eye hole mount while the shock was properly mounted.
Give us an update on handling with the parabolics long term, I'm curious about them.
