Builds AK HJ-75 (1 Viewer)
I plugged the exhaust on my webasto with mud. It got a code as well. After factory rep looked it over said all
good, looked like a fuel code. So I replaced the pump and filter. Doesn't seem as hot, but it works.
The fueling makes me nervous for some reason. Hope it works for you now.
@coldtaco ..... "Charles, did you loose your tie clip?"
... Been wondering what happened to that. :)
Studs on my snow boots were wore out so pulled all the studs(about 6hrs of pain). Got new studs-grooves-sipping. Should be good for a couple more seasons. First pic is tire with old studs next to studs removed.
Since I had the truck the front tank would be pressurized every time I opened the fill cap so I finally tried to do something about it. After much hassle I got the filter for the vent removed and it did not let much air through, either way but I assume it is only supposed to flow one way. Got a small engine fuel filter from Napa and installed it. Will see after I drive the truck if this solved it. The bigger body one is the original.
All my Landcruisers and my Dyna truck have done that, petrol and diesels. I think its due to vapours separating from the fuel and expanding from being shook up. Rear tank does it also.
I just went out and checked mine. It hasn't been started for over 24 hours but it still had a small amount of pressure in both tanks. The front one had slightly more. Its sitting in the sun on a cool day(for summer here) ,maybe 28-29c.
Maybe your rear tank has something not tight that allows it to vent off at the slightest pressure.
It not something I have ever worried about.
My old Dyna would almost blow the cap off as you unscrewed it on a hot day.
