I have this Wix filter minder and it always maxes out to 25 in. H20 Shows clogged even though the filters are new
Im on a turbo diesel and have a Safari Snorkle so not sure if it makes that big of a difference.
I have Tried 3 New air filters
Toyota OEM paper non-washable 17801-68030
Toyota OEM washable 17801-61030
Wix OEM replacement 42159
seems fine when no filter is installed is the factory air filter really that restrictive?
I may try an aftermarket performance filter such as K&N or aFe or even S&B to see if flow improves
S&B W-2443
K&N E-2443
aFe Pro 5R 10-10008 (Oil) or Pro Dry S 11-10008 (Dry)
if it's true that the OEM air filter is that restrictive im sure it's filtering great but performance is really suffering
but it seems you can achieve the same results with K&N you just have to use it correctly
I believe the proof is in the pudding if there's no dust found in your inlet then it has good filtration
