- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
I have done the off road game for a long time, mostly in the desert, some off road racing, etc. Have fallen for the air filter advertizing/myths/BS, a new filter is best, change them often, etc. A few years ago a buddy who works for the biggest local heavy equipment shop, started an argument about air filters, turns out he had the facts. An engineer from one of the air filter manufactures (IIRC Donaldson) had just put on a seminar on how to get the most from your air filter. The next time he was in, brought the handouts, titled something like; Changing the air filter is the best way to wreck your motor. The seminar points:
1: Most damaging debris gets into the motor during filter service, do it as little as possible. Be very careful to fully clean the housing, gaskets, etc, when doing filter service.
2: The second highest damaging debris contribution is from the first part of a new or cleaned filter life. New or cleaned filters are least efficient, they get more efficient with debris loading and are most efficient just before they are too loaded, cause power loss.
3: Inspecting a filter is almost unless. It can look dirty, it should, that’s it job, but maybe fully functional, efficient. The only way to tell if a filter is fully loaded is by measuring restriction, inspecting will only cause wear to the seals, likely get debris on the clean side of the filter, etc.
4: They never recommend cleaning a filter. But if you do, never get cleaning solution from the outside of the filter to the inside. Only blow, rinse, etc, from the inside out. Be very gentle when cleaning, high pressures can easily damage, rearrange filter fibers, cause holes, etc, especially when the filter is wet.
5: The only way to truly maintain filters is with a restriction gauge. Properly used, will increase life of filter, motor, etc, reduce all related maintenance costs. Properly bolt it together, seal it up and don’t touch it until the gauge indicates it is time.
