Do we want to start calling these pump issues the KDSS lean of AHC?Yep, I plan on a better thread for all this. I was very verbose here to make sure I didn't skip anything. I also had to do a lot of running around this forum to find data, something I want to prevent others from having to do.
Lots more data to add, as I didn't remove the bumper at all.
The saga continues though:
I'm an hour into a drive down to SD and just got an AHC error on the dash. So put away the champagne for now.
Now I get to sit in traffic and rack my brain haha.
This is pretty epic! Thanks for shedding light on this problem and I imagine it's going to be a great resource for many going forward.
To clarify, I think you're saying it's the pump inlet filter that's plugged with debris that's creating the non-prime issue? From the manual, pointed in blue
Couple other questions
1) How hard is it to drop the reservoir and pump?
2) Once the tank is on the bench, I presume it's rather easy to break down the pump and get to this filter. How long is that process?
Thanks again!!
The one question I have on the whole pump assy is the pump attenuator. There is a very large hex in the bottom of the pump head case, and from my inspection I figured that was for the high pressure gas "thing". Love the tech notes on the attenuator, but it's kinda a mystery box on longevity and how to test it...unless there are more notes in the manual.
Also, @TeCKis300 I thought there weren't any pump head breakdown diagrams! But, it's nice to see my analysis of the flow/etc. was correct while cleaning.
Short drives I'm not getting any errors and it seems to function on the freeway as intended. After an hour of going above/below 60mph due to traffic I had AHC errors pop up twice. I'm thinking the 5th accumulator needs to be bled again, if not all the corners.
Very cool. There weren't any breakdown diagrams in the regular FSM. That's when I went digging for more and found the detail AHC documentation I posted in the other thread.
Here's the link again - http://gershon.ucoz.com/TOYOTA/landcruiser200/AHCS/m_ch_0114.pdf
Do you know what AHC error you're getting on the freeway? The lowering function at freeway speeds (~62mph) is likely using the 5th accumulator in some manner to support this function. You might have licked the priming function and just need to bleed the accumulator to fix a slightly separate issue.
@radman do you have a particular way/sequence of bleeding the 5th accumulator? Thought I read you're an avid fan somewhere. I've been starting in Normal height, opening bleeder until solid clean stream of fluid comes out, and then closing. Start the truck back up and go to High mode.
Hit that 5th one first. It’s driver’s side (midline of the truck). It won’t refill until you initiate a lift from N to
Hi.
I go ahead and start the rig and let it do it’s thing after every bleeder (out of paranoia). There’s a summary in the link below.
Post in thread 'The Big Bad Rad Dad LX Build'
Builds - The Big Bad Rad Dad LX Build - https://forum.ih8mud.com/threads/the-big-bad-rad-dad-lx-build.1208847/post-13083196
Couple more notes so I don't forget:
- I had ZERO AHC problems prior to a flush from Normal height. Front struts had been replaced, and I have bled the system previously without issue from Low height.
- Easy access was on often and we routinely go to L or H modes.
- The front driver corner is ~.5 inch lower than front pass corner.
- This occurred after the front struts were replaced, I was bleeding to prep for leveling and an upcoming Tahoe trip. Glad I gave myself an extra week!
- The passenger side looks perfect. I need to get the driver side to match.
- Reviewing the AHC Suspension manual, this kinda makes sense as the front height control assy and valving is on the passenger side?
- Do not pass go. Do not collect 200 dollars. Do not remove the filter when filling the AHC reservoir.
- I think we might need to find a go-to transfer pump and assorted fittings/tubing to facilitate easy, fast, and CLEAN filling of the res.
- Source high quality tubing without plasticizer?
- I always kept a dedicated AHC fluid pump and hose in a sealed bag - I also ran a pump of fluid through the line prior to filling the res.
- The vent on the reservoir is for releasing pressure, I couldn't get air coming in the line to break suction.
- Doing a high volume bleed/flush this might pose a problem as my pump started to cavitate under suction.
- This same suction might have been the start of my problem. Suction causing debris/dust in the res to head to the pump head inlet filter.
- Something that wouldn't happen without suction in res?
- The reservoir is going to get debris/dust in it no matter what due to design, the filler neck cap isn't a crazy tight or solid seal. Behind the rear tires is a very dusty/dirty environment on and off road.
- How do we find out the service life of the attenuator, or how do we test it?
- Do our brethern in EMEA with AHC equipped LC200s have experience in this realm?
- More dust, more dune romping, and more AHC?
Great notes. I think this point deserves extra highlighting.
I not quite following on the suction points you're describing? Are you describing flushing with the reservoir cap on creating a vacuum?
Very good points! Especially concerning filling tubes and dust ingress. Going to be extra paranoid on my next flush (as if I wasn't already). Now trying to decide if I want to make a pump tear down part of my 120K service too. Can't help but think there may be a "little" gunk in there.
forum.ih8mud.com
