LX570 AHC pump filter
Zel
Russia/Nakhodkedel
Hello!
I'm from Russia. I do not know English perfectly, so I apologize, I will use Google translator
Google brought me to your forum. I hope to find help from you!
I have a Lexus LX570 of 2010
I struggle with a jumping hydro suspension. I changed the liquid AHC 2 times. Did not help. Irregularities and holes are perfect! But there is an opposite resonance of the wheels. On my old (2004) LX470, the suspension worked much better!
Recently took the test drive LX570 in 2016 model and realized that the suspension should work just like that, and not like I have.
As a bud something on a vibrating stand the car is going. Therefore, I could change the liquidity, as well as take 4 hydro battery suspension to check the membrane for a rush. All visually whole. Then I took off the hydraulic system pump for cleaning. The pump was not very dirty, but some plaque was present. Tried to pull out the filter, but tore it. I want to order 3 new filters at once, but I can not find the part code. Who can tell if faced with this? I will be very grateful
codes of these filters are needed
Does anybody know if this pump, the actual pump shown here is the same as the actual pump for the LX470. It looks identical, but wondering if it is plug and play. I see the actual pump unit for sale for the LX470 in many places for less than $200. My LX570 is pissing fluid out the bottom of the pump, likely peephole?. Wondering if this could be swapped with the business part of an LEX470. 48901-60010 Lexus LX470 Toyota Land Cruiser 1998-2007 Height Control Pump OEM | eBay - https://www.ebay.com/itm/352584187214?epid=2063238381&hash=item5217a7bd4e:g:dvkAAOSw7mNccktm
Thoughts?
