- Thread starter
- #41
Ok...follow up on progress.
The car is now starts and running after the issue with the distributor. It still needs dialing in, and I have a few things to do:-
1. Timing marks - I noticed that these are not very visible with the timing gun. Assume I need to crank the car to get to tdc and get some white paint on the timing marks.
2. The distributor is still an issue. Wired back to the battery, it seems to draw too much current and the starter labors. kind of a spin sping chuuug, spin spin chuug, when cranking. If I take off the power to the distributor, then the starter motor (which is brand new and geared) cranks really quickly. I've tried connecting the + on the distributor to both the battery and also the old + lead from the coil, but get similar results.
3. Still dreading the accelerator linkage conundrum!
THanks
THanks
