If you're burning 3qt/1000mi and its coming from the turbo, you'll know; the inside of your intake pipes will be soaked. I have a truck that burns 1qt/1000 and its nasty in there, you can't miss it.
a) check the intake upstream of the turbo, wherever you have the crankcase vent. If its oily there then you have bad blowby, probably a ring problem.
b) if a) is clean, check the intake downstream of the turbo. If its oily there then your turbo is passing oil, possibly a problem with the drain line.
c) if a) and b) are both clean then the problem is inside the engine, but somehow doesn't create a lot of blowby... e.g. a head problem like valve guides, gasket, etc.
The drain line might be a good/easy/cheap place to start. If there was any blockage in the turbo or post turbo it would be causing those conditions.
Its too bad you dont have another turbo on the shelf to check things.
When we built Ian's 3B turbo we rebuilt it and it seeps into his intake still. Im not sure what the problem is, but the rebuild parts were pretty simple to install.
I look forward to you finding the issue(s) as it may help us figure out his leaky 60 as well.
