- Thread starter
- #41
Here is the SST the FSM shows:
By the pics of your cross over pipe and intake manifold I don't see any " thing " that worry me about oil being a problem on the intake side ..
Yeah, you had me really impressed there for a bit until it dawned on me that you were talking about the 3B head.Ah, I'm not familiar with the HZ, but I checked the EPC; the stem seals are way down in there. Doesn't look like a job that can be done in situ.
That's what I was getting at, there is certainly a bit more than there was in the past, but you can still see the aluminum, it's quite "clean" relatively speaking.x2.
I might take a picture of mine for you so you can see what 1qt/1000 would look like. Its not something you miss.![]()
I agree.Geez id just pull that head,sump,pistons etc,then hone it,new rings or pistons and rings,get head checked. Not alot of $.
It doesn't really seem worth it to only attack the head if you are already in that far.I wouldn't go that far right now. But I would seriously consider pulling the head with the engine in-situ.
Valve guides/seals are very cheap to sort out if you can pull the head and strip most of it yourself.
I haven't addressed anything else with it, I am going to remove the hose and take a guess at the fluid level, but my thinking is that it's been fine for 7 years, if the line placement were an issue I would think it would have cropped up already, and I also think that is a factory 1HD-T oil pan.What happened with the turbo drain and such?
Your turbo has excessive play. I would say replace it with a gturbo as it a direct bolt up.
Even at just that rate I would already be replacing the head gasket, all the head bolts, a few seals and all the ancillary gaskets on the head (intake, exhaust, etc.[i.e.. the expensive ones])
All those parts would have to be replaced again with any bottom end work that needs to be done, and while it looks like the head can be done in the vehicle I prefer to have things in front of me on the bench.
I'f you're in that far it's a pretty hard justification to not just go ahead and replace the piston rings as well.
I am thinking the bottom end bearings are still in good shape, so other than the rings and few of the cheaper gaskets there is not much above and beyond the head job.
At first I did not think you could even remove the head in place but Toyota went and split the timing cover back case to make a relatively easy job of it:
Rubbish.
There's meant to be play in there.
~John
Thanks!Rubbish.
There's meant to be play in there. ~John
I did not re-shim any of the valves, simply noted that the intake were all still sitting pretty and the exhaust were getting to the snug end of spec. Motor has always been stone cold for the checks, over 48 hours in this case.When setting the valves, set them to the looser end of the spec. Make sure that you set the valves when the engine is COLD and has not been running for between 12 and 24 hours. We find that less time, and the valve set is not reliable. ~John
Part of why I feel any engine work should include a piston and cylinder re-fresh as well. I did replace everything in the turbo.The pistons on the 1HZ are not particularly beefy, and if you have ring land degradation it will cause oil burning to occur.
Did you replace the seals in your turbo? That might be a possible cause... usually it's pretty obvious.
Changing brands of oils can also cause more oil consumption, as can other factors. ~John
I tend to have more spare time than money, but I've got neither at this point.I don't know how much spare time and money you have. But I'm really against un-necessary work on my own vehicles. There is no way I'd play with pistons and rings unless I knew they had a problem.
I also have no problem re-using gaskets and bolts that work and come away clean. Inspect, measure and re-use if they check out.
A head on and off is half a day tops each way. It's at least half a day to pull an engine (I can do mine in 3 hours, practised), more to put it back and you still haven't done any of the internal work at that point.
The other issue is the upgrade thing. If I was into the pistons and rings on a 1HZ, I'd not be in for that much work to replace them with standard pistons. Graeme was talking about aftermarket 1HZ turbo pistons available in Aus with thicker crowns.
Yeah, sounds like the same thing, no1 was weak, 2 was better, the rest were fine.When i pulled my pistons no1 was the worst,no2 not a lot better then the rest looked kinda ok. You say no1 was down on compression: mmmm.
Throw it back togethor and go on your trip with extra oil or postpone it and pull the pistons and rings have a look. I was in the same boat as you when mine needed doing,the cheap fix for a cuppla years worked out good. You can allways pull in later and get it bored and rebuilt properly. I bought a cheap hone and ring compressor,really a simple job if you take ya time.
Worst of it is being under the sump,a bit messy at best.
Typical these things rare there ugly heads just before a planned trip![]()
Yup, you stated that as the reason for your view in the post, appreciated. It's good to gather multiple opinions.Well it was out of manual spec....
I know they have axial play.
