Sorry for the lack of updates, I've been kinda bummed with a broken truck in the driveway and temps pushing 100* here.
So, motor = no good.
Last year we decided that since August here in OR is way too hot for our liking that we would save our pennies, take the month off and drive to Alaska.
Instead my wife flew up there last week and I'm stuck here in the heat.
Anyway, we were able to get my folks out here for a visit a couple weeks ago, the plan was to take them around the state (which we did), camp, and monitor the motor condition for a go-nogo on the AK trip. We did about 1400 miles and by about halfway through it was apparent that it would be a no-go.
The good news is that I fixed the oil burning issue with the turbo rebuild, we didn't loose any oil on the trip, but apparently the turbo needed to be rebuilt due to slowly increasing crank-case pressures as a result of the #1 piston failing. We lost power and developed a rhythmic stumble. Removing the oil cap or dipstick shows a synchronized puff-puff-puff of blow-by. By the trips end we were a 5 cylinder, cold starts are pretty rough, the number one cylinder won't compression ignite until the friction builds up some heat.
All that considered, the truck still ran remarkably well.
In all likelihood we probably could have driven to AK and back, but the risk to motor and truck (and wallet) is just too high to justify.
Instead my wife had her sister scrounge up some flights and she flew up there earlier this week, cheaper in the long run but a real downer.
So I've been moping around and trying to stay out of the heat. But I got off my arse this past week to get some work done, the motor is not doing any good in the truck even if I can't afford to fix it, so yesterday afternoon I took the motor out and today I worked on tearing it down a bit.
Before I pulled the motor I did another compression check, all pistons were fine but the #1 was 175psi lower than it's already lower reading from before.
Here is a video of the blow-by at a road-side stop from the trip:
