Adding A/c Condenser Fan to 03+ LX470 (2 Viewers)
The pressure switch is on the car already if I'm not mistaken. It's just a matter of acquiring the electric fan and relay to get it powered up
Oh ok that makes it easy do you know where under the hood its located?
I thought someone posted a pic of it once. There's an empty connector in the front by the AC lines going into your compressor. That connector used to connect to a factory e fan but Lexus/Toyota didn't feel the US gets hot enough so they saved money
Thank you I will follow the line from the compressor.
@Biga27110 It’ll be the cylindrical thing on the driver side, behind the bumper, inside the frame rail. It’ll have a glass sight on top to view the refrigerant through. Below, there is a plastic connector with 2 wires coming out of it. That’s where we’re adding 2 additional wires. You’ll have to disconnect the connector to add the new wires.
This
I just re-read the first 2 posts and @Red Beard posts and it all makes sense now it's time to acquire the parts
I really gotta draw that diagram. But yeah it’s not too complicated. Just gotta get all the different parts and spend a couple hours putting it all together. 2 hours tops.
I think the crucial part when you identified which 2 wires you use from the switch
This would really help a lot of us. Maybe a quick cell phone video would be the fastest and easiest.🤞
I’m far from home at the moment, in Yellowstone. When I get back next week I’ll put something together
Im trying to search partsouq for the possibility of doing an OEM integration as well. I believe i found the part number for the OEM AC fan relay for the pre 03.
8863060090​
Another thread Im referencing.
I believe this is the connector from my research 90980-10940. Need to confirm im not positive.
I can help find the part numbers and connectors can you help how to wire up OEM integration if we can get the parts.
Edit: It appears the Toyota OEM connectors are Sumitomo. For those interested in doing more research https://ackconnector.com/automotive...roof-socket-for-toyota-6189-0144-90980-10940/
Thanks! I will give it a try and report back if it fits.
btw find the pin part number for this: 82998-12480 x 2 and 82998-12440 x 2
