Tapage
Club 4X4 Panamá
So quick noob question, I'll need to bleed each injector one at a time after installing block off plate correct? Just use manual pump to do this?
I didn't have to ..
Yep, no more tapping noise!Did removing the ACSD cure the tapping noise?
Honestly I'm not sure how many miles are on my engine. Odometer shows 105,000 km but it was rolled back or cluster replaced in Japan.And one more question , how many klms before it started tapping?
Thanks for the advice, I'll keep an eye on itOk, I guessed that might have been the case. Ive seen other ACSD go around 300000klms, that might give you an indication of the real mileage. These types of pumps usually need a rebuild the closer they get to 400000. Look for signs of lost power at the top end when the pump gets warmed up.
FYI, not sure if they just packaged the wrong o-ring in there, but the 22193-64750 I received is not the right sized o-ring.Much more expensive (and probably unnecessary to go this route), but the Toyota OEM parts for the blanking plate and O-ring (fits 90-92 HDJ81 / 1HD-T)
2261256350 - plate (~$23)
2219364750 - O-ring (~$3)
Still widely available.
Ahh, '92. Maybe that's it?That’s weird, it fit my pump perfectly. What year is your pump? These are for pre-92.
The blanking plate fit perfectly thoughAhh, '92. Maybe that's it?
I’m doing it because it is the source of a leak in my fuel system. They say this is the place fuel leaks most commonly start.I know this is an old thread but I am in the middle of having my IP w/ ACSD worked on so I wanted to know why some people are deleting the ACSD? Yes, I read all the posts but the reasoning behind this delete still isn't clear to me.
Figured now would be the time to ask while my IP is out of the truck. IP timing will be done when I get the IP back on.
So since this came up, I have a '92. Is this the correct part for the '91-'92? Damn I wish the 91-92 had a designation.I ended up just picking the correct o-ring from the Toyota dealership (part # 22193-17840). Probably overpaid by 3x, but still cheaper than getting it shipped.
The plate will fit, but the O-ring may be different. You could buy both O-rings if you're unsure (the one I listed and the one acarlton listed).So since this came up, I have a '92. Is this the correct part for the '91-'92? Damn I wish the 91-92 had a designation.
