AC / Heater system turns off and on when I hit a bump
Laguna Beach
My AC and HEATER SYSTEM, not the blower above the passenger's feet, turns off and on if i hit a bump.
Any ideas on what is causing this?
If it's not blowing any air then it has to be related to the blower motor or it's controller circuit. Check the motor connections first (under the dash) then i would check it's fuse and relay. It wouldn't be a blown fuse but it's possible it could be loose. Find the relay and see if there is an identical one near it for something else (not related to the a/c system) then switch them and try the air out. Relays can stick when they age and it's a simple, pretty cheap fix.
