235/85 R16 Blizzak W965 on the HDJ81: a Verdict...
Sooo, winter's finally over (I hope) and it's time to finally close the discussion about the 235/85R16 Blizzak W965 tires I installed on my HDJ81 before winter.
Overall, you'll say? In a few words, They're OK, but I wasn't impressed.
This tire is definitely not soft like some others of the brand. The tread, after 15,000 km, shows surprisingly little wear. This is definitely a TRUCK tire and a completely different beast from what I've heard and seen from the DM-Z3 Blizzak series.
Traction wise it was OK, but definitely no better than the Nokian Hakka SUV I had on the winter before. I sure wish I could have gotten those in my rim size and tire diameter...
On dry pavement the tire does not have great huggability and doesn't hold very well in corners.
On heavy snow(we had plenty of that last winter) the performance ws OK, but not as good as I expected. Although it has a fairly deep tread, the blocks are fairly close together and the tread pattern is not as conducive to good evacuation as the Hakka was.
In light slush and on fine packed snow its performance was satisfactory. In heavy snow it wasn't great. Traction wise I found the rubber not that grippy. On hard packed snow and on ice performance was actually better than I expected. I was also able to pull a truck and a car off of snow banks uphill twice this winter, without any lack of traction, but I credit the locking diffs for that
. To be fair, though, as long as I wasn't high centered (happened once, darn snow bank) the tires performed well.
In conclusion, I would say this is probably a good general winter tire that is probably designed for a much heavier vehicle. As a matter of fact, the tread has worn little over 15,000 km and it has decent snow and ice traction but it is fairly stiff and below par in handling.
Is it a good choice for an 80 series Landcruiser? I would say you would probably be better off with a slightly lighter and wider aspect ratio tire.
After one winter I would say the Hakka SUV was better after two winters than this tire was new.
I would also take the opportunity to tip my had to SUMOTOY as far as tire profile goes. Indeed, you were right, the narrow and tall
aspect and stiff E load rating did substantially affect road handling in a negative way. It is not sufficient to be narrow (to get through the snow), you must also have wide lugs to get rid of the packed snow and a wider aspect tire to keep that tread flat on the road surface.
My next winter tire for on the road use? Most probably an 18 inch tire, studded, in 70 aspect ratio for good handling, around 255-275 tread width with wider lug spacing at the shoulder and tons of siping at the center.
I invite everyone to comment on their choice of winter tire and what they think of them after one winter.
Regards,
Chris
