Builds A 1994 80 Series gets an LQ9 GM V8 (11 Viewers)
Making a power steering pressure hose:
Step 1: cut up a perfectly good power steering hose
r2AjderFvWtIOzCO_TyzcllROEDmjiGvrBrduBXQBi2d9w5EN64-29vzdXIrmYCPoMkvf17A7fDeWO3P_RgnUESwqz_Xby5KWgCdZ9gtyJu_9_RQc5AKfxTkjaup4tEXow
Step 2: bend & flare
5xxev5KuyFXB3JRFf1H44-mNyIxT-ZYMfDP-yheu4ffJviqbHfI3wgC3lrR4CytMygASyj8KPC3gAYOUrBJsE0pkwh9s90PsRVEwYpUFCu21ISF2G_kTtQ6tblM0LnF18Q
finished product:
HFxWJZggziP9kyRgS98_uBvai6mPERNDoglW_4dJOOmyCcS5SWK4gIrNXUnuBkk4g2VhpITuHmQ1jemKOlp1NhAwiIqKtPPbHq070rYM0M9XFfZ38SviIU4yP-hyiVoceg
installed on the truck:
I1Ryk5Khu-gZP4fkNf6lGkHE2l4gzHfjHUjGWkB6a6SnzdIecNpwRB68xGgBNBvvXx55y97I0SsJ82zM3L6BXOT2XzKE5ZYJ-OzolMUC42tEsTw03PLtcozvKIeSL3hLlg
dkUuzs80HuA0ttHz6Gb1v2-ZLKC4qvuYm1mLjKC28CUKEoa3uPgoDOTYFTHNAdiExAk6Y70x6np4hDYWPDdGBVP8sJfXvsZ7N9WcoAy6dQVVFemOLEtrKGib4l_E9W3EAw
What would be the ultimate if you guys were using all OEM hardware on the brackets and stuff.
That would be the bees knees.
OEM hardware for which manufacturer? GM or Toyota? Haha!
Does JIS count? Where would someone find OEM Toyota hardware? They would need to know some kind of Toyota parts Guru......
What was the purpose of dimpling the holes in the motor mount bracket?
...via IH8MUD app
If you have a dimple die you don't need any other reason!
These two pieces come with the adapter, but they need to be offset:
zJVbVchmuACpjZqFlYIWn59LJVXzSq_tKEL5FRnxJyuFwGj78tWlGjRLl_ij2GiiaLMGqZMziMi_J48nxqtIuxc3auIyYoillIYatSCV_eEiN0j0IcB_aORGg4t8NKN9oQ
TtQNdsOnjdYI9D4R5hGbQEKPdF7FkAKnfIHZyqGIaTTtk9PaWh538ghGN9IgiUu7hlxRC_O08LPt986AxcIk1M4UOljj2CAo-Ypua4aS2XtVSvstoqFJ38B_PD_ld6YZmQ
UkzJs3gvUehT4yBOUAhasTAFyIebLJ5PrXcrvUD9VPBTMKh3MDApICTbCjyJdd4RHxY_VUMztUJYogDtNgKp-F-1ooAXLyM2SyE7Bm49VWDw5kg4RzmHXUIXzSsowmQbLg
_lpjw1zMN_kMep0TR5Fb-3nRzca0ri5dbd47aL6lBqf39dF7hrfgbM3jFqFkUvNLuI56RCvSCCS9DItulpmZQtJ1OGG_8Ll5i2y6CY5G59cFzeh0_TITj7sHdIvC73GOHw
I do the same on my builds. I don't understand why Marks does this on 95-97 cruisers..... Annoying... Especially at a 1400$ price tag
The original shifter had positions for P R N D 2 1. (or rather “L” instead of “1” in the case of the 80)
The GM 4L65E that’s going in has P R N D 3 2 1.
...making room for that extra gear:
Before:
MFmJb3fPtbfXorYitV_43uV7DwKE_qkHNT1ViJVWpn5pbmKv6dmYrh9cZVV9PGB2bvMr-caPYp_jHcNB90m1HtcXlaKj8e9afZdPJCKcfw_w1uUXXu7LQuNBC9gPtQIZ4w
After:
_Jz4C26mWBg3xTC66wY6Q_A4pqiD8489mducYziMNWPv4GJ0k5MgVAiZjIQLEf-d0SRrHJUWbA-VaTg3BqQQBWCEBPMrzmgY_39ScRd0YG7ghruGPSghuKAbaIOC_0yaEg
Loving the installation pictures and detailed notes. Awesome job, can't wait to see the completed product. When can I drop off my truck:bounce:.
As mentioned earlier in the thread, our approach to the change in shift pattern is a little different that others have done by using the 3FE 80 shifter. We started by carefully buffing off this factory piece:
324Tq_pihQzMMeRuOi6r22gH_ZgyHV4ooRlTKBfdo4CpaP4UUXTMkI1kwCVFHVonZtu12j7jKxy5A06m1N4JfqHmfZKklAO3m1Lxet8OPLFPf4m4lxqbRor1q3TV-_k89g
It leaves behind nothing but clear plastic. Then, we had a vinyl decal made to match up to the new shift points:
The OLD pattern:
PPqtg83tC4-0Dy9XmKxfSv7_pg33dSUlq9HhphoHo-8MwPtokyyDwgnWDhOW6TDa3s7FkIjZLAAxNHFKSOPg_TPVRPiSL0vHvuFXzZOKt_yYHFt5kl7rkjJx7W4SeljOpA
...and the NEW pattern after buffing off the original PRND2L & adding the vinyl decal:
JT6lWS6ew0dS-yvsTp3PrNvFZaxDKQ9v663JeqsXlm3Q69wOfsLnFUK6Efui5zTf5BuyU2ug7eECCXOwihY5jYt4RBFRrk6EGcjGXxj1_KBEGshkmXLVfMHlPV-BUnY6Lw
HjEuRfpvIPpRmqhDen69f3nFtZaTGgN_-ATLT75tuykkPFbFUIudu3H9py9qB2OgLy9ZDahThUVFDoDpiZ3FK2TPPnesy987GP2JSxAqCTHNRaUU6GtebvnpGeia9qZfNw
GOkh86nKpv9zLYQeHwn9jz1iBw0hjulApaN9ofyOzwcWvC8PioRW2MsI57sj6SMLoRkZbJt7cSdY-MXw-j8yp06228RXJQUIv8ImXyPlqY-QT7sAcZ_amcDfidk9TzwyRA
  • OCGX
