Build A 1994 80 Series gets an LQ9 GM V8
Making a power steering pressure hose:
Step 1: cut up a perfectly good power steering hose
r2AjderFvWtIOzCO_TyzcllROEDmjiGvrBrduBXQBi2d9w5EN64-29vzdXIrmYCPoMkvf17A7fDeWO3P_RgnUESwqz_Xby5KWgCdZ9gtyJu_9_RQc5AKfxTkjaup4tEXow
Step 2: bend & flare
5xxev5KuyFXB3JRFf1H44-mNyIxT-ZYMfDP-yheu4ffJviqbHfI3wgC3lrR4CytMygASyj8KPC3gAYOUrBJsE0pkwh9s90PsRVEwYpUFCu21ISF2G_kTtQ6tblM0LnF18Q
finished product:
HFxWJZggziP9kyRgS98_uBvai6mPERNDoglW_4dJOOmyCcS5SWK4gIrNXUnuBkk4g2VhpITuHmQ1jemKOlp1NhAwiIqKtPPbHq070rYM0M9XFfZ38SviIU4yP-hyiVoceg
installed on the truck:
I1Ryk5Khu-gZP4fkNf6lGkHE2l4gzHfjHUjGWkB6a6SnzdIecNpwRB68xGgBNBvvXx55y97I0SsJ82zM3L6BXOT2XzKE5ZYJ-OzolMUC42tEsTw03PLtcozvKIeSL3hLlg
dkUuzs80HuA0ttHz6Gb1v2-ZLKC4qvuYm1mLjKC28CUKEoa3uPgoDOTYFTHNAdiExAk6Y70x6np4hDYWPDdGBVP8sJfXvsZ7N9WcoAy6dQVVFemOLEtrKGib4l_E9W3EAw
What was the purpose of dimpling the holes in the motor mount bracket?
...via IH8MUD app
These two pieces come with the adapter, but they need to be offset:
zJVbVchmuACpjZqFlYIWn59LJVXzSq_tKEL5FRnxJyuFwGj78tWlGjRLl_ij2GiiaLMGqZMziMi_J48nxqtIuxc3auIyYoillIYatSCV_eEiN0j0IcB_aORGg4t8NKN9oQ
TtQNdsOnjdYI9D4R5hGbQEKPdF7FkAKnfIHZyqGIaTTtk9PaWh538ghGN9IgiUu7hlxRC_O08LPt986AxcIk1M4UOljj2CAo-Ypua4aS2XtVSvstoqFJ38B_PD_ld6YZmQ
UkzJs3gvUehT4yBOUAhasTAFyIebLJ5PrXcrvUD9VPBTMKh3MDApICTbCjyJdd4RHxY_VUMztUJYogDtNgKp-F-1ooAXLyM2SyE7Bm49VWDw5kg4RzmHXUIXzSsowmQbLg
_lpjw1zMN_kMep0TR5Fb-3nRzca0ri5dbd47aL6lBqf39dF7hrfgbM3jFqFkUvNLuI56RCvSCCS9DItulpmZQtJ1OGG_8Ll5i2y6CY5G59cFzeh0_TITj7sHdIvC73GOHw
I do the same on my builds. I don't understand why Marks does this on 95-97 cruisers..... Annoying... Especially at a 1400$ price tag
The original shifter had positions for P R N D 2 1. (or rather “L” instead of “1” in the case of the 80)
The GM 4L65E that’s going in has P R N D 3 2 1.
...making room for that extra gear:
Before:
MFmJb3fPtbfXorYitV_43uV7DwKE_qkHNT1ViJVWpn5pbmKv6dmYrh9cZVV9PGB2bvMr-caPYp_jHcNB90m1HtcXlaKj8e9afZdPJCKcfw_w1uUXXu7LQuNBC9gPtQIZ4w
After:
_Jz4C26mWBg3xTC66wY6Q_A4pqiD8489mducYziMNWPv4GJ0k5MgVAiZjIQLEf-d0SRrHJUWbA-VaTg3BqQQBWCEBPMrzmgY_39ScRd0YG7ghruGPSghuKAbaIOC_0yaEg
As mentioned earlier in the thread, our approach to the change in shift pattern is a little different that others have done by using the 3FE 80 shifter. We started by carefully buffing off this factory piece:
324Tq_pihQzMMeRuOi6r22gH_ZgyHV4ooRlTKBfdo4CpaP4UUXTMkI1kwCVFHVonZtu12j7jKxy5A06m1N4JfqHmfZKklAO3m1Lxet8OPLFPf4m4lxqbRor1q3TV-_k89g
It leaves behind nothing but clear plastic. Then, we had a vinyl decal made to match up to the new shift points:
The OLD pattern:
PPqtg83tC4-0Dy9XmKxfSv7_pg33dSUlq9HhphoHo-8MwPtokyyDwgnWDhOW6TDa3s7FkIjZLAAxNHFKSOPg_TPVRPiSL0vHvuFXzZOKt_yYHFt5kl7rkjJx7W4SeljOpA
...and the NEW pattern after buffing off the original PRND2L & adding the vinyl decal:
JT6lWS6ew0dS-yvsTp3PrNvFZaxDKQ9v663JeqsXlm3Q69wOfsLnFUK6Efui5zTf5BuyU2ug7eECCXOwihY5jYt4RBFRrk6EGcjGXxj1_KBEGshkmXLVfMHlPV-BUnY6Lw
HjEuRfpvIPpRmqhDen69f3nFtZaTGgN_-ATLT75tuykkPFbFUIudu3H9py9qB2OgLy9ZDahThUVFDoDpiZ3FK2TPPnesy987GP2JSxAqCTHNRaUU6GtebvnpGeia9qZfNw
GOkh86nKpv9zLYQeHwn9jz1iBw0hjulApaN9ofyOzwcWvC8PioRW2MsI57sj6SMLoRkZbJt7cSdY-MXw-j8yp06228RXJQUIv8ImXyPlqY-QT7sAcZ_amcDfidk9TzwyRA
