98 - 2000 100 owners - Is your Transmission Original or Replaced? (1 Viewer)
My '98 has 206,000 miles now. it still has the original tranny, I learned from this forum to drain and refill the tranny and avoid do a complete tranny flush. Btw, I am the original owner.
My 2000s tranny finally died yesterday- 2 miles from the dealership... I am so glad it did the first 90 miles just fine.
Toyota reman/ rebuild going in. 1yr/100,000 miles
$3500 out the door. Then they gave me a 10% off coupon. $3150 out the door after discount-
Teton Toyota and Service guy Travis very fair I thought... Final verdict on test drive.
Sent from my iPhone using IH8MUD
and what were the symptoms? sounds like you were on the way to the dealer anyway when it went?
1999 with about 190k... assuming low/poor maintanence given what I've found on the rest of the LC... haven't addressed it yet either.
Running well on original tranny as far as I can tell.
Mine was a 2000. I've since sold it, but put a new tranny in fron the dealer around 80k. It sounded like a box of rocks when it died.
Mike.
question: I can't find an answer, is Royal Purple ATF okay to use in these transmissions? I see people mention using M1 and Amsoil ATF, but not Royal Purple.
I don't know about their tranny stuff, but the local guy who is the differential rebuild guru has a bench full of "purple casualty" third members:meh:
Really? :eek: I use royal purple motor oil and a K&N oil filter, so I put RP gear oil in the transfer case. The low range shifter doesn't have any vibrations to the touch at speed anymore. I used M1 gear oil in the diffs to save $50. :idea:
2000 LX470 158K original tranny so far no problems I just bought this 3 weeks ago. It will get the amsoil tranny fluid in it very soon. I will also change the filter in it too.
I use RP in tranny, tcase, and differentials. So far no problem. Knock on wood. I struck a good price with RP. Was cheaper than Mobil1 at the time of purchase.
Build date for my 2000 was 12/99.
1999 (Build date: January 1999)
116,000 miles
Original tranny
No issues
Still on original transmission with my '99. 162k with normal maintenance at Point of Sale dealership.
2000 LC
build date 09/99
139 k miles
No transmission problems that I am aware of.
I am the third owner and I believe it is the original transmission.
Tranny fluid changed at 115k
1999 model
build date of 12/98
205,000mi
Changed fluid at 87,000, probably should do it again soon...
No issues.
Is there a tread like this for 2001 and newer? The build date listed on my door is 09/00.
99 Hundy build 04/99
130K miles
No issues
Reg service according to owners manual
Sent from my Android using IH8MUD
  • Back
