97 Cruiser Replacement Front Left ABS senor
Alaska
Hello all, currently in the process of servicing/sealing my front knuckles/axles and all that fun stuff on my 97 cruiser and came across my front driver side ABS speed sensor was partially broken and needs replacing. Any suggestions on where to get just the sensor and not the harness? or do i need to replacing both?
On later model cruisers the speed sensor is only available as the entire harness. Unfortunately $$$$ if purchased new.
Is the sensor itself damaged or just the wiring going to the sensor? If just the wires, they can be spliced. I haven't heard of a compatible alternative sensor, but others may chime in if they have come up with something.
