The 1HD-T
Pretty sure he said it's a gas engine, so 1fz-fe?
The 1HD-T
Front drive flange 43421-60040 runs about $68. However, that is for the later model stub axle with longer splines.Thank you, that is nice to know. Is a drive flange a major fix or cost? It doesn’t matter because I will do what I have to.
I definitely agree, I am trying to find someone in Ohio that might specialize in Land Cruisers.Many of us here have a justified lack of faith in Toyota dealerships, and mechanics in general.
You have a 30 year old car that very few Toyota based techs have any training on.
Most independent mechanics will make more from basic oil changes than dealing with a 30 year old dinosaur for a fastidious enthusiast.
I agree. I already have $25k invested and I bought a Land Cruiser for keeps. As the old saying goes- In for penny, in for a pound.So worth it in the end tho.
And still less than one would spend on a modern financial arrangement and product.
Gotcha, thank you.A drive flange, a broken birfield, any "open" in the drivetrain will exhibit these symptoms. You put your foot to the floor to get the truck to move because you're relying on the friction of the viscous coupler in the transfer case.
I meant clunky jolt, sorry.I had to drive home from Michigan which was about 4.5 hrs. I had to stop and get gas about an hour from home and that is when I noticed problems. I put it in reverse and it had a clunky joint. Also, when I got back on the freeway I had to put the gas to the floor just to sluggishly accelerate. When I got home I felt 5he center console and it was extremely hot.
forum.ih8mud.com
I will do that this evening and post as soon as I can afterwards. Today I am doing the family holiday stuff, unfortunately. Thank youWhat happens when you put it in 4-Low?
Here is a pic of the engine bay data plate. Not the best pic but it is legible.Look at the tag on the door and itll tell you what transmission is in it. Take a pic of that sticker and post it. Between all of us here, Im betting we can get it figured out.....
It is definitely gas. It’s funny because I was about to import a JDM diesel triple locked when I saw this one come up for sale. It saved me the hassle of importing a L.C. I will check the shifter later this evening and post back asap. No it wasn’t me that posted on FB. I will try the 4 low as others have mentioned, thank you.Is it gas or diesel? If it’s diesel it may be the hydraulic A442. Does your shifter have L,2,3,D or L,2,D? Easy way to tell if it’s electric or hydraulic.
Someone on FB had this exact same thing come up. Was that you? I said the same thing several others have said. 4 low and see what happens. Sounded like a stripped flange.
A442F is the Transmission
K294 means triple locked.
I dont know anything about the color or trim numbers.![]()
Thank you for the help.Important to know if it wasn't mentioned already; when in 4LO (transfer case shifted) you (generally) should be on a loose surface (dirt, gravel, grass) as the center differential will be locked. If you drive it on dry pavement you'll only be able to drive straight ahead for a short distance, then reverse straight back. The gearing is very low so you can't drive much more than around 35mph in that configuration. Steering will become very hard if not impossible to turn the wheel if on pavement.
If you can't pull the transfer case out of LO after your test (fully stopped) you can reverse or go forward just a few feet at time and try pulling on the shifter until the driveline relaxes. When the transfer case does shift out of LO you may hear/feel a loud clunk (don't worry, you didn't break anything). Just a heads up.
