Okay the factory style Y pipe for 93-94 isn't available and even if it was I want to move away from the dual sideways cats so for those that have installed the Magnaflow Y pipe or even the Bosal 95-97 replacement Y pipe what did you do as far as the oxygen sensors? My 93 has 2 sensors, one for each cat. The replacement pipes have one sensor bung in them. Can I just unplug a sensor or do I need to weld in another bung? Heres my plan for redoing the exhaust when the time comes, sooner rather than later. Use either the Magnaflow, Bosal or even the Walker Y pipe designed for the 95-97 models with an integrated cat. Use the built in cat but no second cat, build or reuse my stock pipe to go over the frame, install a universal higher flow muffler and then adapt a stock tailpipe or just create my own, maybe side exit. Im looking for optimal ground clearance, ease of replacement, and cheap. I don't really care if its loud or quiet and inspection isn't an issue for 2 more years at which time I can register it as an antique anyways
