Replacing pads and rotors does not require bleeding the brakes. But if it did, my scanner will usually suffice.FWIW: Ask your indy mechanic how they intend to bleed the ABS circuit...
I've often looked at the ABS ECU page of TechStream but never had an extra set of hands available to bleed and actuate solenoids together, so haven't done the deed. The SST spressomon refers to is a high dollar box of trickery that plugs into the ABS controller under the hood, it's not the "hand held tester" aka TechStream unfortunately. Anyone who has seen/used the ABS SST and TechStream care to compare and contrast?Can we not do it with tech stream? I've been meaning to flush my brake fluid but if I can't do it without a tool, I'm going to have to fork it over to Toyota.
^ the reason I mentioned it: Presumably, the OP's brake fluid has never been flushed...or at least given the condition of his front brakes its been more than a few years since doing so. Now, with the brake work, would be an opportune time to completely flush and renew the brake fluid...since brake fluid can accumulate water vapor over time...thereby potentially diminishing braking performance and introducing corrosion to an expensive braking system.
Normally I'm on a 2-year brake fluid flush for the rigs I intend to keep. And given the only efficient method I am aware of for purging the old potentially contaminated fluid from the ABS circuit utilizes an expensive SST...just trying to bring a little awareness to his, et al, game.
How about engage abs a few after the initial flush? Won't that cycle the fluid? Not perfect but better than the old fluid in the system.
I thought Brembo was the OEM manufacture? Maybe I was totally off on that. I didn't actually do my homework on that fact. I just took someone's word on it from this forum.Usually OEM Toyota rotors have a ton of thickness to them and can just be machined. Machining rotors and replacing pads on a 100 series at a lexus dealer is around 330-450$ depending if you need new shims and hardware or not. Rotors are about 200 bucks a piece for OEM and rarely need replaced because they are good quality(by far better than brembos I bet) and should last a long time with just machining. Tell your dealer you want a price for new pads and machining rotors. If you do it yourself, you may save some money, but if you screw it up it could cost far more. Example: A lady's son did an oil change on her nice 2 year old lexus to "save her some money". Lady was taking the old oil to a place where it could be disposed of. Oil spilled onto lexus carpet (about 2quarts worth or more), oil pooled up underneath carpet and got everywhere. Did about 1800 bucks worth of damage to interior-expensive oil change indeed. Point is, if you do it yourself and screw it up, its on your hands. If a dealer or shop screws it up its on their hands and no additional charge to you.(Unless you get a really bad shop or dealer)
That makes sense. I think every two years is more often than needed but e little extra maintenance never hurts.
You can generally just gravity bleed the brakes if you keep the reservoir full and not really worry about the abs. Just don't let it run dry.
Quote on Lexus LX570 from Lexus dealer. Rear brake service $307.00. New pads, resurface, etc. Plus they give me a free loaner for the day, normally a new ES350 or RX350 and I never have to refuel it. Local Toyota dealer wanted $330.00 for the same job and no loaner.
Maybe my next one (100/200) will have to be a Lexus...
