80 series Rear Heater Delete Hoses - Do You Want One? (2 Viewers)
SoCal
Heyyy ery body.
So I have a potential hook up for a batch of part number 87245-60420.
This is the heater hose that replaces the u-turn hose and fittings, which is used when bypassing the rear/floor heaters.
In the picture it is the red hose. It eliminates 3 hose clamps and leak points, and is just a much cleaner look when performing this mod.
I want to judge the potential demand before making the order. They will go for $55 each, which is 20+ dollars less than anywhere else on the internet and I'll take venmo payments.
So, if you want one let me know and I'll see if the amount makes sense.
Is that shipped or??
Heyyy ery body.
is there NOT a DELETE service cap involved too still ?
mmm, not sure what you mean by service cap. are you talking about putting two 5/8" hose caps on the 2 unused heater pipes after yanking out the old stuff?
no , not exactly ..............
- NOT simply cheezy 5/8" SAE garbage from advance auto parts China Chairman MOE made sadness.....
- rather , OEM TOYOTA 16mm LIFETIME general service parts delete , and maintenance service 3 layer EPDM oil and chemical proof caps ..
- the
Cat's MEOW status level grade JAPAN. Spec. ones ,
- MICE will go inside , die and smell to the WALKING DEAD in no time .......among other reasons too ..............
- the
- the
I don’t have the caps though. Any 5/8 cap should do though. Do you have a part number for them? I can check my supplier.
- the
Thanks! Ordered two for my rear heater delete to cap the lines in the engine bay. With shipping just under $2 less than HPS caps. I like the cleaner look and quality of OEM. Appreciate your post and products!
