80 Series Hidden Winch Mount
If you have a 1993 this is what you will have to do in order for the Trail Taylor hidden winch plate to fit. Previous post from TT said this was tested on a 92, 94 and 97 with no issues. I am definately having issues getting mine installed. Still won't reach the mounting holes and I am having to drill new ones. I have to say I feel duped into believing this would look like the 80 in the photos TT has on the website. Should have saved the $480 and put it towards an entire bumper. This was not worth all the fab work I have done. I'll post the finished work later. Thanks for all the help.
I had the same issue on my 1993. It does not fit 92 through 94 period. I had to modify the bracket by cutting the back on about 2” and resending it and have it powder coated. Only then was it able to fit the bumper in the stock position. That is what you will have to do to have it work. I can send you some pictures. I was disappointed as well because it only made for bumpers for 95 on with air bags that have wider bumpers I believe.
I considered trimming the back portion of the mount but was concerned about compromising it's integrity and loosing bolt down surface area. I'm sure it would still be stout enough as it is built well and the metal is thick. I also had a problem with hacking off any part of a $480 winch plate.
$480 for a $30 piece of 1/4" plate? And it only fits 3 out of the 7 years it says it does?
So.... There are three holes on my 93 frame. 2 are have threaded captured nuts and the middle is just a hole. If I move the plate back it leaves me with one hole that has a captured nut to thread into and the plate covers the second captured nut. My thoughts are I could put a nut in the frame and that would allow two bolts on each side. My only concern is the load will be more isolated on one part of the winch plate. I tested the plate by lifting the front of my rig with my jack (not all the way) and felt the plate for movement as I lifted. Nothing could be felt. I'm a winch noob so I have no idea of the stresses involved. Anyone have any input?
Thought it over. This is the best solution for a maddening situation. Looks the best and I think it'll be strong enough. I'm going to put a grade 8 lock nut in the empty hole. Cut a crescent in two washers and bolt it up. Pic on the right is using the two threaded holes. It significantly bumps the bumper away from the body. Even my 14 year old didn't like it. Left pick is using the factory bumper holes in the stock location. Much better. Still don't care for the front of the winch plate sticking out, but oh well!
Here is what I did. Cut of back and had new back plate welded on, then extended the holes forward to use threaded holes as contemplated. Cut hole through from bumper like yours.
That is an option that does give you two anchor points. Although imo too close together to disburse the load creating a stronger attachment to the frame.
You already cut the bumper, so at this point I would go back to the original mounting location holes and either double nut everything. Or do what I did and chisel off the captive nuts and through -bolt and sleeve all three. I know it sounds like over kill but I’d do this for recovery points and especially for a winch. Yes it will stick out of your bumper like you were told it wasn’t supposed to, but it will be solid.
Or chuck it up on the classified section and it will sell. Use your profits towards an aftermarket bumper.
I finished up. I thought over the mounting points and went with the 2 bolts next to each other on the frame. I would have liked the load to be spread out more but I tested the winch plate with only 2 bolts in by almost lifting the front end off the ground with my jack. Since the bolts in the plate are massive compared to the bolts actually holding the winch on. I'm guessing the winch bolts will fail before the plate to frame bolts would. Here's the finished project.
Overlapping washers like that is very not good! The washer on top is going to sit at an angle which is putting a huge side load on the bolt going through it. Bolts don't like that. You could probably get away with an 8.8 or lower grade bolt fine, but a 10.9 or 12.9 bolt is likely to break when loaded like that.
You can notch your washers so they sit next to each other flat. You can even buy washers already clipped for this if needed.
They are notched. Wrong pic.
I thought about welding the back part to the frame but I'm not completely sure I'll keep this setup. If I decide to keep it I may at least run a short weld on the side.
This is been on the To Do list for A WHILE. Sorry for the delay on this but it has been insanely busy for me. We make HWMs for the 100, LX470, GX470, LX570 early and 200 Series early and late with nearly 400 units in the field worldwide.
These will be made from laser cut 1/4" HSLA steel and CNC bent. Fully welded and come with fairlead spacers for those that want the fairlead away for the bumper face as shown (different folks for diiferent strokes)
I'll be making three small changes and then these head to the laser cutter for production. 1) lower the winch approx. 1/2" to operate the clutch handle more easily, 2) Full surround on fairlead and 3) underside cross winch plate brackets for extra support and more strength.
Pending laser cutter time these will be available in 2-4 weeks powder coated with hardware.
Sorry about the "donor" 80... It is a Carr Fire rescue and we I use for R&D.
Next up......to set my front and rear bumper jigs and to release the rear tire and jerry can carrier arms to use with the stock rear bumper.
Jason
View attachment 2722510View attachment 2722511View attachment 2722512View attachment 2722513View attachment 2722514
Are these for sale? I checked the site but didn’t see any
If my memory is correct, the 91-94 bumper is shorter that the 95-97 bumper. So you may need to cut a whole in the bumper for the front of the plate (where the fairlead bolts to) to protrude through.
I could be wrong.
I realize this hidden winch mount only works for the 95-97 bumper. Are they still available?
Oh I thought they were discontinued! Great to hear and looking to support if they become available for pre-95.
I’m not familiar with the EBay winch mount, but Jason made me a Trail Tailor hidden winch mount last week.
Me too! It’s a work of art.
@Will Van what fairlead are you using and how are you planning to locate and cut the bumper hole?
…and looking to support if they become available for pre-95.
I think that product development is unlikely. It’s just a matter of real estate - There is not enough room behind the 1991 to 1994 bumper for a winch.
I am cheating and using my OEM winch bumper with a Warn Zeon 12S. I am going to try to re-use my Yankum hawse fairlead.
