that number shouldn't be too surprising as quite a few of are driving around heavy, phat pigs!7500 lbs??
So your lspv and booster are original? As in 30 years old?I have (4) new OEM calipers and new back rotors, the front rotors are stock. Original booster. ABS is disabled (fuse out) due to bad pulsing when coming to stop at times, LSPV is stock, never looked into this. ON the road, brakes work fine. The only time I have issues is extreme down hill or up hill in off road angles, I have to hold on the brake really hard to keep it from moving, like its not going to hold if I need to wait on a hill.
I think powerstop may be better but I wanted to keep the stock rims so DBA was the best in my opinion for a 16” rim.Since we're chatting about brake upgrades, which rotors are better between DBA and Powerstop? Suggestion on semi-metallic pads or is there a better pad material?
@Shoredreamer what's your weight, and what kind of brake upgrades do you have?My 93 is 5860# (on 315s & spare, winch, Avid front and rear swingouts and GOBI) and my 97 is 6140# (ARB bumper, 4x4labs rear, winch and full campteq kitchen on 255s & spare) 7500# is HEAVY
I totally agree, and that's why I added more HP! I like to travel heavy and with comfort in the back country.My 93 is 5860# (on 315s & spare, winch, Avid front and rear swingouts and GOBI) and my 97 is 6140# (ARB bumper, 4x4labs rear, winch and full campteq kitchen on 255s & spare) 7500# is HEAVY
YesSo your lspv and booster are original? As in 30 years old?
OE replacements works for me. Fronts came from Napa, rears are Centric from RockAuto.Since we're chatting about brake upgrades, which rotors are better between DBA and Powerstop? Suggestion on semi-metallic pads or is there a better pad material?
Yes, I would say you maintain them for sure...1997 LX450 with 100% OEM brake system. I run 35s on the street and 36"Swampers in the woods.
I can chirp tires on dry blacktop and don't have issues holding position on an incline.
However, I maintain my brake system. I have 2 full sets of calipers that I swap between. One set gets rebuilt using all OEM parts and put on a shelf ready to swap in.
Fluid gets flushed when I swap calipers or when it starts to get dark (should be clear), all soft lines have been replaced with new OEM and get inspected yearly.
Wow. I would fix those before upgrading the front brakes.
It's more important to stop than it is to go.Yes, I would say you maintain them for sure...
Ali,@Shoredreamer what's your weight, and what kind of brake upgrades do you have?![]()
had a horrendous experience with greenstuff pads many years ago, as did a friend of mine, both of us having them completely fail once warm. Hopefully they fixed this issue on the newer generation pads... but my trust was completely eroded after that.Great feedback on the brakes, should help out others. I think I've run the Greenstuff pads on both SUVs at one time which I loved quite a bit.
I recall your 80 is heavier than mine, but daaaaamn![]()
lovely looking bit of kit that!If you have the $, @synapse has an awesome front and rear set up. I was able to test drive his set up and it feels and stops like a modern truck. His 80 is on 38s!
Thread 'Bespoke Front and Rear Big Brake Kit(Bigger than big) with Electronic Parking Brake' Bespoke Front and Rear Big Brake Kit(Bigger than big) with Electronic Parking Brake - https://forum.ih8mud.com/threads/bespoke-front-and-rear-big-brake-kit-bigger-than-big-with-electronic-parking-brake.1290784/
