80 Series 3D Printed Parts
This piece of trim that's missing...
The upper 2 holes for mounting break off
This is so niche it's ridiculous, but I'd really like something to fix/replace the ashtrays on the rear doors of non-power window versions of the 80 series. It was really hard to find pics online, but here's some pics from a non-power window model GX variant out of Japan:
Placement is slightly different on the pov-pack version door trims, but the actual part seems identical. The problem with this part is the plastic outer "holder" for the ashtray insert, while looking similar, is actually made out of a different kind of plastic, and it goes very brittle over time. At this point if you just look at them funny they shatter, meaning the ashtray falls out and you're left with a void. Both of mine on my 80 are broken. I don't care about the ashtrays themselves, but the hole in the door doesn't look great.
I've got three ideas. One is just a blanking plate to cap off the hole, that screws into the tiny metal bracket that hooks on the door card, and closes off the hole. Essentially an ashtray delete. Or you could duplicate the outer bracket itself, so you can refit the ashtray. What I'd really love to do for my 80 is replace the ashtrays with usb ports for charging. Since I've added the door wiring harnesses (usually not present on base model 80s) so that I could retrofit central locking, I'd love to use the wiring for the power windows to each door to run USB charging circuits instead. I know @Delta VS has a few solutions in this area, but not for the base 80 rear ashtrays.
If you send me the ashtray I'll send back a plate with the ash tray. Just order the other ash tray plate
Obd/fuse protector but with cutout at the top for scanguage. Be able to cover this mostly again instead of leaving open. Something like this already around?
How about a drivers side right arm rest, to fit down into the little box that's on the side of the center console? Are there any folks with 3D printers out there that could come up with something like this?
The single most overpriced POS plastic part on a 80. This isn't a 3d part request, it should be a metal aftermarket request with mounting options for add on accessories. If Dave from @Delta VS crawls back from underneath the rocks, him and his team should strongly consider a aftermarket replacement.
Pretty simple until then, when you remove this part release the bottom from inside and push the upper part up to release.
Hi Everyone,
I love this stuff and I have just purchased an Ender3v2 for making stuff for around the house and a few parts for my 1992 80 Series Landcruiser and I am having problems finding a part for the front A pillar grab handle .... I have looked everywhere to find a print file or something to help me print it and I cannot find it anywhere...
I have included a link below to a shop here in Australia that has the part but it is and has been out of stock for over 12 months... Does anyone have a file for this or know how to help me recreate this part.. I would be very appreciative of any help from anyone... Thanks In Advance Tim.
I sell em
I sell em
I'm in Melbourne Australia.. do you have the print files or do you just sell the parts and if so how much for the cost of the part and postage to Melbourne Australia please.
Headlight leveling window caps.
