Probably not, but I'd do what the book says. I"m lucky, the 2009 specs the 75w-90, which is easily available.The book says
Transfer SAE 75W
Differential 75W-80 GL-5
Is it going to hurt anything running 75w-90 in the diffs? I would think not. This is a 2016
Seems 75W is for the transfer, and even after reading all this .. I wonder what difference it would make running 75W or just plain moble-1 syn 75w-90?
Not yet discussed, is the dealer is using whatever is in the 55 gallon drum they have, and that almost certainly isn't Toyota special SAE 75W only.
I Wonder Why Toyota would keep Specs s Secret for this One Lubricant, When the others are known?I'm baselining my new-to-me 200 and part of that process is all new fluids. Looking up the specs, Toyota calls for "SAE 75W Toyota Genuine Transfer Gear LF" fluid. 1.53L, for the record.
My discount parts source is $53.63/Liter, MSRP at the counter is $81
What about this stuff is so special?
I went ahead and bought it from Toyota, knowing it'd be good for 60k miles, and not knowing what is different. Physically, it is a lot darker brown than any gear oil I've ever seen.. even the Toyota 75w-85 diff oil. That stuff is a light golden yellow.. I'm attaching a pic of the Transfer gear LF, brand new, in a clear container. It also smells much stronger than normal gear oil. Whatever that unique smell is.. this has a LOT of it.
Speculation: thinner for better mileage, and the needs of the transfer case not being particularly demanding.
People have discussed this in other threads, citing VOA, and saying it didn't look too advanced. I know it's difficult to find a straight 75 weight gear oil.. Amsoil doesn't even list a product for our rigs.
Any input?
Virgin oil:
I just changed my TC gear oil using the Toyota 75W LF. I assume the factory fill was also the same. Cost was hard to swallow, but if I only have to do this every 60k miles it's not as bad I guess. I wish they came in more convenient bottles and not the can. Plus I hate throwing away 1/2 quart, but I would rather have a little extra than not quite enough...
Side by side comparison of new vs 65k factory fill. Light usage, So Cal truck, little to no towing.
This oil is really dark when new though. See the first post. That was virgin oil from the can and looked well used.that's pretty dark for only 65k miles. I pulled mine around 75k miles and it was slightly darker than new, but definitely not that dark. These bandits are definitely gauging us on the fluid cost though. I did like the canned packaging, which really helps preserve the oil almost indefinitely until opened. I don't think any other automakers still packages fluids this way anymore.
I fly a corporate jet for a living. The oil used in the engines is called BP 2380. It is also sold in cans. We stretch a latex glove over the top of the can after it's punctured so preserve the oil. I would think that would be acceptable on the Toyota oils as well. I plan to do the same for mine.
I put my extra into empty M1 gear oil bottles I had from another vehicle.you could also pour it in a sealable container (i.e. something with a lid that closes air tight).
I changed mine again after 40k and that took less than a year and a half.. but yeah if you are adding miles that slowly tossing the extra is probably the best option. “Only” $25 worth from the online pricing I guess..What are you planning to do with the extra? The TC is sealed so you shouldn't need to top off. Save it for the next oil change? I am planning on disposing of mine as my next oil change 60k miles from now is > 10 years.
No issues here with Amsoil Severe Duty 75w-140. I think I have around 7k post breakin. Not a lot.I am getting some Nitro 4.88's installed next week. After the initial 500 miles, is it better to go with what nitro recommends or find something else?
I’m betting it’ll do great. That fluid is GL-5 and my understanding is the chemistry often used to get that spec can lead to issues with yellow metal parts, but your early model case shouldn’t have any of those to worry about.So I have a 2008, which calls for 75W-90 for the Tcase, but I used the Ravenol MTF-1 75W-85 for a recent change of the tcase fluid. Think that is any thing to worry about?
