Rebuilt truck and motor. Got it back on the road last year. Runs great for a period of time but now wont idle without choke. Aftermarket Trollhole carb. Took it apart and cleaned out ethanol gunk from jets. Was good for a bit, but rough again. Been running non ethanol and additive.
New gas tank and lines. Fuel bowl stays full at sight glass level. Holley electric fuel pump, two filters.
Stock distributor but found electric wire looks questionable. Photo attached.
Checked valve lash. Timing at dot. Played with adding 5 degrees advanced. One vacuum hose from carb to distributor. Pulls vacuum between 10 and 15.
FWIW has reground cam little hotter than stock.
Aftermarket coil.
Carb idle solenoid is seeing constant 12volts and clicks, seems operational.
Tried second new carb with similar results.
Tried adjusting carb mixture and idle. Wont idle under 1000 rpm. Needs some choke to stay running. Dies at stop signs and hard to restart. Needs choke to start even when warm. Running aftermarket gauge cluster.
Plugs were black from running with choke. Replaced with E3s I had lying around. A little better but not much. Have a new set of plugs but need to check gap.
Checked spark with light. All plugs causing light to flash. Took plug out and getting a spark. Not super hot but I can upload a video if it would help.
Ideas or thoughts to try? I could do compression test. Have maybe 100 miles since rebuild. Thanks in advance. I'd love nothing more than to get this baby running and reliable.
Aftermarket coil.
