'77 FJ40 buildup in Charlotte (finally)
The new one appears to be made of better materials, thicker walls, and with a better weld process. (although I wasn't smart enough to get a picture of them side by side)
Got the shaft installed in the transmission, and everything put back into the truck. Buttoned it all back up and took it for a test drive. It appears that we are back in business, but I now have a small leak on the transmission pan.:mad:
After all that crap, I decided to get back to the rear bumper/tire carrier mount. I had to change a few designs from the last one because the two-piece tailgate hinges and latch would contact the old design.
Looks the same, but the measurements are just a little different.
Greg came down last week to finally drive the thing. :clap:
We spent some time on the rear tire carrier. He wanted a basket that would hold a good size cooler or possibly three jerry cans. We built this, then decided that it messed with the departure angle and side clearance too much.
Does anyone want to buy a basket that holds three jerry cans?:grinpimp:
Ended up with this for a final configuration. The basket was made from 1 inch HREW. What is hard to see is that it is built right onto the DOM tube of the swing-out tire carrier, rather than build separately and attached later.
That is an awesome rig. One question though and of course, to each his own. Why no spring over? Seems that with your level of skill, you could have built a SOA setup that would function far better than the Man-A-Fre springs (Which I had and removed for a spring over).
Of course, I still love it and am not trying to tell the owner how to build his rig.
The friend who I'm building the rig for had specific wants. One of those was highway cruising comfort. I personally felt that this meant spring under for this specific build. (actually, toyed with the idea of coilovers and links, but decided we had enough work to do)
Edit: Oh.. forgot to mention. He's got a house that was built in the early 1900's, so max height to enter the garage is 80 inches.
Danno, I am serious about the basket. Ping me off line if you are interested.
Jim
Decided to be on the safe side with all the talk of broken pinions and add an antiwrap bar. Burned some time on MUD and decided to follow Camcruiser13's lead. I ordered the parts from Dan at Ruffstuff.
I ended up having to push the axle mount over next to the carrier. When I welded the threaded insert in and attempted to thread the heim joint it, I gauled the threads.:mad: Gonna have to try that again....:rolleyes:
Picked up the rear bumper/tire carrier up from powder. I won't do final install until after the paint shop finishes with the paint buffing on Friday, but it sure looks pretty. While I was at it, I had the soft top window frames done for the half doors.
Cirbo, that looks great.
... and I can't decide who has it better... you, for being able to focus your tremendous talent on building a modern FJ40, making quality the top priority, or the customer, for being able to retain you for this task.
No doubt about it, you've both got it good.
Thanks for sharing!
I've got it better. Greg has been great about the entire build. While he's very opinionated about the truck, he's never questioned expenses and has allowed me freedom in decisions and design. I've learned a whole lot about these trucks and building in general that I would not have done without this project.
