77 Clutch adjustment question
Carlstadt New Jersey
When adjusting the slave cylinder for the 3-4mm fort tip play as per the chassis manual, is it done without the return spring on or off?? Safe to assume it is off??
make sure you check it again after putting the spring back on
I adjust mine with or without spring. You want the slave to be fully retracted ,sometimes the rod /piston in the slave may not be fully retracted after removing the spring. Especially if someone touches the pedal and pushes it slightly out. Then your measurement will be off once you put the spring back on.
