I've searched and found a couple other threads with the similar issue. Got some good ideas but while the majority of others that were clogged, they were clogged with the red rusty water. I drained the coolant from the radiator and then went to remove the cylinder drain plug and the freeze plug. It is clogged with hard black buildup. Read from another post that it maybe some of the radiator leak-stop stuff.
I've banged at it with screw drivers, chissels, put frame hanging wire and old speedo cable on the end of a drill and went to town on it. I'm pretty sure I've made it to the cylinder wall but it's still not draining fluid. It looks like I've got to the opening to the left of the drain hole but there's still more crud in their blocking the coolant from draining.
I've seen how others have used a pump to flush it with muriatic acid. Do i need to have the coolant flowing through the blockage to do that flush? Or will the acid eat up that build up if it just sits in there? I'm thinking of making a hose attachment/fitting to the drain hole and then filling the hose up with muriatic acid and letting it sit for a bit. Would this work?
I'm out of ideas and I've been going at it for 4 hours today. Any tips/tricks technique would really be appreciated!
Also the engine is still in the truck so space is limited, but I do have the flywheel, clutch, transmission and transfer case pulled.
Edit: Think I found my answer here: F engine block flush/ muriatic acid
Will try it out tomorrow.
If you want to try to attack the blockage at the Drain plug with muriatic acid, a way to do this and use a lot less acid is to insert a fitting where the drain plug goes, attach a hose to that, raise the other end of the hose and put a small amount of acid in the hose... give it a while to become exhausted, lower the hose to drain it out, and do it again... possibly several times.
If the acid is doing anything you will have some fumes appearing at the top of the hose most likely... and the acid will be heavily discolored yellow as it drains.
Mark...
