6X series Unobtainium (4 Viewers)
Dude, I might need to borrow those for cloning….
I’ll carefully pull them out this week. I have an other package to send off for another mudder. PM me and I’ll get it out this week if I can.
Mine are in rough shape and I never wanted to install them. They’re too bent up to sit flush. However, they are 100% there including the gaskets that mate to the body.
There are 5 clips on each side. It looks like the back end has the pilot punched for the mounting screw, but it was never fully drilled out. The end caps are crimped on by the sheet metal.
The clips were available 60 days ago from Toyota. Looked like they are used in a number of Toyota vehicles. The 'punch' or dent was not meant to be drilled out - rather a way to keep the rear plug in place.
This came off a 24V HJ61 …
I do not know a part # yet … ?
I will carefully bring it back to like new condition ….. I hope 🤞
LED of course 😎
Those are the right badges
Fog light switch rear
84160 90A03​
All the mounting hardware is still available I replaced the blinder clips, the little body receivers for them, the front mounting screws, and the body-side screw grommets as mine were barely hanging on.
For both sides:
9353064020​
4
$ 0.79​
SCREW, TAPPING
9018904001​
4
$ 1.89​
GROMMET, SCREW
6777220021​
10
$ 1.13​
CAP, FRONT DOOR TRIM RETAINER
7586720020​
10
$ 2.59​
CLIP FOR ROCKER PANEL MOULDING SET; ROCKER PANEL MOULDING.
Part # 07049-20511 PLATE , ENGINE NAME
2F Fire Brigade valve cover decal
Below is the original photos or it does not exist photos
and microfiche parts diagram as well …
I never knew about this, till this non-usa valve cover found me :D
and I heard the calling Inside me to reproduce it to help foster its historical significance in more then one way …
I also produced a TECH video on the topic as well …
It’s intriguing when you happen across BIG FOOT and it’s actually real and the 2F FIRE Brigade Land Cruiser was a REAL thing to in JAPAN !
it appears my boy Hunter is keeping it REAL too ......... :popcorn:
- seeing this image and my period correct artwork passion for details that matter affixed in the correct PLANT A11 factory installed location
truly has made my Friday a warm one , thanks ! :idea:
Here are some photos of my non-us fj60. It has the 60-40 split front row, third row jump seats and ambulance doors. I live in the Tampa area if anyone ever wants to see it.
I just picked up a 60/40 front bench but the one I have doesn’t have the notched leg bolster like yours. Is that custom?
Also is there a special “center” console for the 60/40 front bench or it’s just the hand break and that’s it?
Only console I know of is covers for diff lock levers. There is not much room for anything else.
