- Thread starter
- #201
While we were removing the drive shaft, my son found the drive line bolts were spinning freely in the pinion flanges. This is prompting me to put a wrench on the entire truck. We had to remove the 3rd member because it was leaking between the axle housing and the drop out. I forgot to take pics but the ring and pinion looked brand new with very minimal wear. Since we were in there, we also installed new outer axle seals. The new rear bracket I got from Poser bolted right up, as did the new rotors (Poser has the centers machined to clear the axle ends). With the new calipers bolted in we called it a day. Still left to do on the rear axle is a new frame to axle braided line (see pic, pulled very tight), cut and flare brake lines and get new caliper braided lines.
