- Joined
- Dec 8, 2006
- Threads
- 158
- Messages
- 2,974
- Location
- Greenfield, MA
- Website
- thecarpentryway.blogspot.com
After some careful thought, I came up with a way to put a 60 series column into my HJ47. Why do this? Well, there are a few advantages to be had:
-three switches (hazard, lights, and wiper switch) are moved off the dash to the column, which is by and large safer and more convenient
-I gain intermittent windshield wiper function (with the addition of the correct wiper controller box into my harness)
-tilt steering (though there are non-tilt 60 columns as well)
-with the exception of the final few years of production in which collapsible column appeared, 40 series trucks had a rigid steering column. With the 60 column, you gain the advantage of collapsibility and breakaway bolts, which is a safer set up in case of front end collision.
Anyway, I manged to document the sequence I used with photos, so here we go.
The first problem was figuring out the attachment of the column to the firewall. I could have modified the firewall to accept the 60 hole cover, but I was looking to avoid that, as there was not a lot of room for the 4-bolt pattern on the engine side of the firewall (stiffening rib in the way of one of the captive nuts that would need to be welded in). I could have chopped the 60 column and adapted the 40 series column end and dust cover onto it, but this didn't make sense from the point of view of how the 60 series internal steering shaft is supported. Also, the twist-lock column engagement feature on the bottom of the 60 column, where it attached to the hole cover, looked a bit more well thought out than the primitive arrangement on the 40 column.
So, I decided to chop the inside section of the 60 series hole cover and graft it into place on the 40 hole cover. I had two 60 columns on hand, one from a 1981 BJ60, and the other from a 1983 BJ60. The columns were dissassembled and the lower mounting flange, which twist-locks into the hole cover, got it's four spot welds drilled out so I could change the column length by shortening.
