- Joined
- Dec 8, 2006
- Threads
- 158
- Messages
- 2,974
- Location
- Greenfield, MA
- Website
- thecarpentryway.blogspot.com
- Thread starter
- #21
Having done most of this, I was insterested in the difference between how a late model FJ40 mounts the column to the firewall vs. my 1969. It looks like you were able to adapt nicely. That said ...
- My column is too low in my lap and needs to be raised. And that is after I installed a mini-truck steering wheel which I believe has a smaller diameter.
I gather that you didn't modify the dash to allow the 60 column to come up in height? That would explain the low steering wheel position.
I looked at it, when I hummed and hawed about this conversion, from the point of view of getting the centerline of the 60 series steering column, ie,. the steering shaft, to the same original position to which the 40 mounted. The only way to do that is to section about 0.75" or so off the bottom of the dash lip so as to bring it up. That 3/4" or so at the dash is all the difference.
I found that sitting in the seat with the normal large steering wheel held in position, that the clearance was fine - with a mini-truck steering wheel the clearance would be plenty.
i have pondered this since my 60 p/s conversion tilt would be cooolll
