5-speed A750 trans won't shift in to 5th gear. (4 Viewers)
If the issue stays fixed, will you reinstall the speed calibration unit to see if it comes back?
Yes. I'll give it a few weeks and if I feel comfortable that everything is working properly, I'll reconnect it.
I'd be lying if I said I didn't just shop the s*** out of 200s this last weekend.
I think we'll add some cooling seats to Gerry and at that point, what's the difference besides an extra 150 HP?
Having owned both, the LX570 is as much better all around than the LX470 as the 80 is better than the 60. And the extra horses are really there, it's not advertising BS.
Just my humble opinion.
Not helpful! I'm trying to save myself money!
You would as always regret it.
Imagine if you had a really nice 80 with a couple problems... But you sold it 10 years ago before the value went way up. That's basically what you have now.
That having been said... I would sell my 100 for a 200. Yep.
We have both and still take the 100 almost everywhere we go. Those arm rests are just the best things ever for road trips.
We’ve been trying to figure out which one we would trade in if we ever got something newer and we think we would trade in the 200.
I'm sure I'd regret it. Even my Ms loves the 100 and is constantly reminding me about "the devil you know", having gone through it and maintained it so thoroughly.
But that extra 150HP...
Sounds like you need to supercharge the LX...
...now there's an idea
That 150hp is REAL nice lol. If I could drop the 3ur into my 100, it would be perfect.
This morning I installed the 2 new rear ABS harnesses. I opted to go with "WVE" brand on Rock Auto as some posts here mentioned pulling Denso parts out of WVE boxes. I don't think I was so fortunate, as I couldn't find Denso anywhere on the parts, but I didn't find any other markings either. But, the brackets were correct and they had the correct number of the push-in plastic 'place holders'. I did need to adjust the position of some of the clips just to give the right amount of slack here and there. Took me about 30 minutes to do the pair, which included 2 minutes of looking it over, 30 seconds to make the right side harness connector crumble, 2-3 minutes of cursing, and 5 minutes of contorting myself to tediously pick out the remaining plastic of the original sensor side male connector.
Before replacing, I'd disconnected the battery to get fresh readings on the dash (and ultimately Tech Stream). To my disappointment, as soon as I put the truck in gear to exit the garage, the VSC lights returned. 2 more minutes of cursing.
Then I hooked up TS to see if I'm still battling the same codes. Interestingly, I'm not! I only showed C1336, which was "Zero Point Calibration Deceleration Sensor Undone" or something similar.
Did a google, found a thread, did a fresh ZPC, and all is well! No more lights on the dash and my VGRS light behaved correctly (as far as it went away after doing some lock-to-locks and hitting 25-30MPH around the neighborhood. This is good as it was coming back at each key cycle the last week and wouldn't go away for a few miles at 50-60MPH.
I also found a light disconnected in my tailgate for the reverse light. I thought I'd get lucky and it would turn off the 'brake light out' warning light on the cluster, but no dice.
Regardless, I think we're in better shape today than yesterday. If anything changes, I'll update here.
So to summarize the fix for my truck: I don't actually know for sure. It was either a combination of very coincidentally timed errors which happened to lead to the same outcome (no 5th), or the truck is so in touch with itself that one item going bad made the other items think they were bad as well. Actual replacements done were: new trans (no fix), new ECM (temporary fix), new speed sensors, L4 switch, external harness, 86 of speed calibration (currently fixed), rear ABS harnesses and ZPC (currently fixed with no lights).
Ce matin, j'ai installé les 2 nouveaux faisceaux ABS arrière. J'ai opté pour la marque "WVE" sur Rock Auto car certains messages ici mentionnaient le retrait des pièces Denso des boîtes WVE. Je ne pense pas avoir eu autant de chance, car je n'ai trouvé Denso nulle part sur les pièces, mais je n'ai pas trouvé d'autres marquages non plus. Mais les supports étaient corrects et ils avaient le bon nombre de "placeholders" en plastique à enfoncer. J'ai dû ajuster la position de certains des clips juste pour donner la bonne quantité de mou ici et là. Il m'a fallu environ 30 minutes pour faire la paire, ce qui comprenait 2 minutes de surveillance, 30 secondes pour faire s'effondrer le connecteur du faisceau côté droit, 2-3 minutes de jurons et 5 minutes de contorsion pour choisir péniblement le plastique restant du connecteur mâle côté capteur d'origine.
Avant de remplacer la batterie, j'ai débranché la batterie pour obtenir de nouvelles mesures sur le tableau de bord (et finalement sur Tech Stream). À ma grande déception, dès que j'ai mis le camion en marche pour sortir du garage, les voyants VSC se sont rallumés. 2 minutes de jurons supplémentaires.
Ensuite, j'ai connecté TS pour voir si je me bats toujours contre les mêmes codes. Curieusement, ce n'est pas le cas ! Je n'ai montré que C1336, qui était "Zero Point Calibration Deceleration Sensor Undone" ou quelque chose de similaire.
J'ai fait une recherche sur Google, trouvé un fil de discussion, fait un nouveau ZPC, et tout va bien ! Plus de voyants sur le tableau de bord et mon voyant VGRS s'est comporté correctement (dans la mesure où il s'est éteint après avoir fait quelques verrouillages et atteint 25-30 MPH dans le quartier. C'est bien car il revenait à chaque cycle de clé la semaine dernière et ne disparaissait pas pendant quelques kilomètres à 50-60 MPH.
J'ai également trouvé un voyant éteint dans mon hayon pour le feu de recul. Je pensais avoir de la chance et que cela éteindrait le voyant d'avertissement « feu stop éteint » sur le tableau de bord, mais rien à voir.
Quoi qu'il en soit, je pense que nous sommes en meilleure forme aujourd'hui qu'hier. Si quelque chose change, je le mettrai à jour ici.
Donc, pour résumer la réparation de mon camion : je n'en suis pas vraiment sûr. C'était soit une combinaison d'erreurs très coïncidentes qui ont abouti au même résultat (pas de 5ème), soit le camion est tellement en contact avec lui-même qu'un élément en panne a fait penser aux autres éléments qu'ils étaient également en panne. Les remplacements réels effectués étaient les suivants : nouvelle transmission (pas de réparation), nouvel ECM (réparation temporaire), nouveaux capteurs de vitesse, interrupteur L4, faisceau externe, 86 d'étalonnage de vitesse (actuellement réparé), faisceaux ABS arrière et ZPC (actuellement réparé sans feux).
Bonjour,
Je suis en France, je viens de relire toute la discussion car j'ai un problème similaire sur un hdj 100 (diesel) de 2005. BVA 5 vitesses a750f
Après 15 kilomètres de roulage, témoin moteur, le toyota ne passe plus la cinquième.
Je contrôle les résistances des électrovannes, c'est bon, mais j'ai un doute, vu que le problème n'intervient qu'à chaud.
Dans le doute, je change de boîte de vitesses, je roule 15 kilomètres, témoin moteur, plus de cinquième.
Je change le calculateur moteur, le défaut revient mais systématiquement après 35 kilomètres.
j'ai un code erreur techstream 62(3).
Le faisceau de boite sur un hdj 100 fait parti du faisceau moteur, ce n'est qu'un élément, ce n'est pas facile à trouver.
Donc, suite a vos infos, je vais tester le capteur de vitesse sur la transfert, si cela ne change rien, la commande de changement de vitesse...
Le truc, c'est qu'a chaque fois il faut faire au moins 40 kilomètres pour vérifier.
Huh?
Good morning,
I am in France, I have just reread the whole discussion because I have a similar problem on a hdj 100 (diesel) from 2005. 5 speed gearbox a750f
After 15 kilometers of driving, engine warning light, the Toyota no longer shifts into fifth gear.
I check the resistance of the solenoid valves, it's good, but I have a doubt, since the problem only occurs when hot.
When in doubt, I change gearbox, I drive 15 kilometers, engine light, more than fifth.
I change the engine computer, the fault returns but systematically after 35 kilometers.
I have a techstream error code 62(3).
The gearbox harness on an hdj 100 is part of the engine harness, it is only one element, it is not easy to find.
So, following your information, I'm going to test the speed sensor on the transfer, if that doesn't change anything, the gear shift control...
The thing is that each time you have to travel at least 40 kilometers to check.case.
Salut France !
Vérifiez définitivement les 2 capteurs sur une transmission et les 2 interrupteurs à l'arrière de la boîte de transfert. J'ai fait une inspection visuelle rapide de l'ancien faisceau de câbles l'autre jour et j'ai trouvé une zone où un court-circuit aurait pu être possible. En remontant en arrière, je crois que c'était le connecteur du commutateur de prise en charge L4 de la voiture de transfert.
Je ne reconnais malheureusement pas les codes que vous affichez.
Hi France!
Definitely check the 2 sensors on une transmission and the 2 switches at the back of the transfer case. I did a quick visual inspection of the old wiring harness the other day and found one area where a short could have been possible. Tracing it back, I believe it was the connector for the transfer car L4 pick up switch.
I don't recognize the codes you're showing, unfortunately.
Salut la France !
Salut France!
Vérifiez absolument les 2 capteurs sur une transmission et les 2 interrupteurs à l'arrière de la boîte de transfert. J'ai fait une inspection visuelle rapide de l'ancien faisceau de câbles l'autre jour et j'ai trouvé une zone où un court-circuit aurait pu être possible. En remontant la piste, je pense qu'il s'agissait du connecteur du contacteur de prise de courant L4 de la voiture de transfert.
Je ne reconnais pas les codes que vous montrez, malheureusement.
Merci, je vais regarder cela de plus près.
