- Thread starter
- #221
way too go Elbert. glad to hear your up and running.
you'll have great fun with that V8.
by the way, who did you send the pcm to for programming?
devo
This guy did the PCM programming / tune.
Jesse Bubb @ Wait4Me Performance
devo
Way to go Elbert.....
Im getting there.... now Im trying to get all the fitting I need for the fuel lines.....
I'll join yah guys soon...![]()
Yep had one of mine do that but what caused it to stay forward was the rod binding due to a bad angle on the mounting surface. Worked great at first then it started sticking. I switched over to an adjustable 40 series rod and it worked great.![]()
Call Jim @ Downey off road. Use his transfer case VSS adapter. I don't know right off hand the part #. But it will be wicked easy if you still have the VSS plug wire on your harness and if it is still in you PCM programming. Very simple to adapt just make sure you tell him it is for a 60 series t-case. Great work and can't wait to see the final pic's.
ditto.
i'm finishing a 5.7 vortec, NV4500 , orion HD conversion on an fj60 right now. we're going to use the output speed sensor on the orion HD to generate the signal for a digital speedo. we're also going to run ( just ordered it yesterday ) the downey unit on the back of the t-case ( where the bolt-on stamped tin cone normally resides ) to generate the required 40-pulse signal for the ecm and to get it pst the ref so we can smog it in CA. the truck is running but still needs a lot of loose ends tied up. i guess i should start a thread about it on here....
keep up the good work!![]()
