I mean these things are clanking up a storm, not just rubbing, but smashing into the shock body.
Thougths? Feedback
Its not the shocks, its the springs. None the less, Chop has a point, its the low quality of the springs. Time for Eibachs.
Sounds like you may have longer springs than you really need. what length are the shocks and what links are your first and second rate springs?
Edit: From looking at your picture your top springs are almost at coil bind. You would probably do better with a slightly heavier rate up top and perhaps a lower rate or shorter coil on bottom.
How much extension is left?
Chop, if you have problems with the lower cups falling out you probably need more preload on your springs or spring tenders..
The FOA's bottom cup is very similar to KING's.
Wait till them little shallow asss lower cups fall off. That will irritate ya too.
You are right FOA and King and Sway A Way use the same design type for the lower cup.
Noahs 16" lower spring is not causing the upper springs to deform. It doesn't matter that the lower is a 16" on a 14" shock. But I will agree that the upper is almost at bind. Which would suggest that the manufacturer has to many coils in the spring to get said rate and should try using a few less. Besides, changing his spring rates would also make me have to change his shock valving. I run the same rates he is and its fine on mine.
Yes, and I too have Eibachs, and they dont do that. I even have a 16" on the bottom. And the same rates too. I was also the lead sales men a GenRight for 5 months. I worked with the owner Tony very closley. I sold about 3 pairs of coilovers every week. The springs rates most often sold for the valving type was a 200/250. Even while on a 14" or 16". We never had this problem because we used KING coils. Not cheap crappy "Blue Coil".
IT is not the spring rates. It is the quality of spring. While at GenRight we ran plenty of 200/200 on 16" coilovers. And those never did what Noahs are doing either.
As for where the secondary spring rate stop is located on a coilover, by moving it up like the picture has it (which is for advertisment purposses only) you completely take away the purpose of having it there to begin with. Moving it up and not using that collar which acts like a progressive rate, is to not utilize one attribute that a coilover gives you. GenRight also ran that stop 1" about the lower springs. Noahs is at 1.5"s if he listened to me.
I gotta ask this. Why would you run a dual rate coilover only on one rate?
even Chop said that his Eibacks do the same thing. I'd be he probably has the same problems. The lower coil is too long for the shock and is the wrong rate, so it distorts.
