Devilmans Hand
TLCA #19517
- Joined
- Aug 4, 2008
- Threads
- 140
- Messages
- 3,475
- Location
- Commonwealth of N.VA
- Website
- www.capitallandcruiserclub.org
hello everyone
So i've been messing with the rear springs on the 4runner today.
I took one side off and added a couple long leafs to the pack from a skyjacker tacoma set Tom gave me a while back.
I reused the main spring and the second spring from the stock pack, and then two long leaves and the overload leaf from the tacoma set.
When I try and install the spring I cannot get the center pin to line up w/ the hole on top of the axle housing. It is off by about an inch and a half or so, sitting forward of the hole.
The 4runner uses a spring over configuration.
I tried jacking up the axle and wiggling it forward to try and line up the pin/hole, but i did not succeed.
I remember having issues lining up the center pin when swapping out axles on Steve's truck and swapping springs on Bart's truck. I don't remember how we solved those problems.
I'm thinking that because I changed the curve of the pack while unloaded that the uncompressed lengths are slightly off.
Should I try and ratchet-strap the axle forward to try and pull the axle to the pin?
Is the stock spring pack on the other side locating the other side of the axle fixed just enough to disallow a little twisting of the axle? And should I unbolt the u-bolts from the other side first?
Am I just SOL and need to do some drilling or modify the spring pack so it is a little more flexy?
Other solution?
right now the modified side sits about 2" higher than the stock saggy side.
Other solution?
