euclid
I would weld it. Correction: I would get a friend to weld it.
All this talk really makes me want to go with the $OR U-Bolt Skid Plates:
Specter Off-Road-Land Cruiser Parts - 290-69-Extreme U-Bolt Skid Plates
So you also want to lower you ground clearance and increase your chances of hitting rocks and other stuff?
I will start with my concern:
There is this rubber looking thing that was between the plate that the shock was mounted to and the spring pack before, but will not fit with the new plates. I would have to very carefully shave it down to fit and that would be a major pain in the ass. Wondering If I should bother or not.
Throw the rubber pieces in the trash. You can get some spacers from MAF that sit around the pin to align the pin in the holes on the axles. The spacers were a touch long when I installed them and I had to trim them down so the top of spacer would not hit the bottom of the axles before the u-bolts were fully torqued.
Question:
Now is there any concern for crushing your shock mounts front or rear?
I didn't notice those spacers at MAF .. can you point 'em . ? ( tha link )
This piece did not touch the axel. it was between the bottom plate that the shock it mounted to and the spring pack.
Here is a good thread on it. I don't think MAF list them on their website. I would of thought they would of started putting them in the kits by now. The metal u brackets on the back can be pulled out too.
https://forum.ih8mud.com/60-series-wagons/67673-not-your-usual-suspension-installation-question.html
I bought a set of those about 2 years ago - they deformed severly during install - no way I could get even close to the recommended 90 ft lbs. Deformation started around 60, and they just kept bending. I sent them back (got a full refund, except for shipping of course). Unless they've changed them, I think it's a crap product.
