4.10 was never an available gear ratio in the US AFAIK. They were all 4.11 from 1991 through 1997.
My 95FZJ80 is 4.10. I know cause I counted the teeth.
Yes! 41/10 teeth = 4.1
Many prior series LC's had 37/9 = 4.111111111111111111111
Well, then one must be a misnomer as Toyota wouldn't have 2 so close for the same vehicle.
Perhaps @beno would be able to shed some light.
Not misnomer, simple math. The diff was redesigned for the 80 series, the early rigs are 4.1111111 the 80 and newer are 4.10.
Well, there's SO much difference between the two ratios that you could NOT possibly run them both on the same rig!!![]()
@inkpot I assume this is in jest because you can, as you know. I am running my old 80 4.10 rear gears in the rear of my FJ40, with 4.11s up front. Works fine. I read, but don't know, that some Chevy's came slightly mismatched from the factory.
Agree with @Tools R Us - The rear diff was fundamentally redesigned with the onset of the 80 series, and the ring and pinion changed from 37/9 to 41/10. And the change took place with the end of FJ62 production. I've counted in my FJ62 and it is indeed 37/9.
Looking at the 80 rear diff housing-the re-design significantly enlarged the oil passages, and the oil capacity seems higher as well Both beneficial changes. The older design has more stiffening "webbing", but the newer design looks like the entire differential is more triangular and stronger. The bearings also changed in the 80 differential as well though that reason is less clear to me. Maybe to standardize with other trucks in the toyota line up?
Why would they do this? What is the benefit?. : 1033"]
Yes, my 60 and 69 Chevy 4x4's had different ratios F/R. 3.92 front, 3.90 rear. It made the rear end pass the front in the mud. 69 was 4.11 front and 4.10 rear.
Fair enough.Likely just what gears were available for what axle. Close is good enough.
I'm running one that is slightly different, and it is a non-issue.
Thought the difference was open diff(4.11) vs locked diffs(4.10).
