Hello everyone, after looking around my engine bay I noticed the bottom screw of my tps was missing, And the top one was tightened down causing it to kind of lever outwards. So I tried to adjust it using a digital multimeter set to ohms. I used a 0.93 mm feeler gauge between the throttle stop screw and lever, probed IDL and E2, and moved it until I saw it just hit infinite ohms (right on the edge of a reading and infinite). I've done it twice to be sure, and it looks to stop in the exact same place when I double check it. But the idle is still high (1000-1200 RPM). I did however notice a mark scratched right beside the idle adjustment screw as if someone had been adjusting it and wanted to mark where they started. Is it safe to believe that my adjustment of the TPS is correct and someone has tampered with the idle screw, or am I just not adjusting it correctly? Funny enough, when it only had one screw in it and was levered away from the throttle body, the idle was right around 600RPM or so. Maybe someone didn't notice the TPS was installed improperly and compensated by turning the idle screw? I'd really appreciate any help.
