Registry 3FE Owners Check-In (12 Viewers)
My 91 with 3FE 256K miles, paid $1200, then it broke, fixed it for $300. I picked up some J springs, shocks and caster cor. bushings, 48x69 confer rack, have a rear locker to install, herculined it, built a huge stinger since the front bumper was gone, 35" BFGs also in its near future. I get 20 MPG HWy,if I drive at 55mph and about 200 miles out of a full tank if I don't watch my speed.
Check in to the right place.
HI All,
1992 FJ80 3FE
The List:Slee 4" Progressive Heavy. , 35x12.50 R15 Dick Cepek Fun Country II, ARB Air Lockers F&R, ARB bull bar with Warn 12m, Kaymar Rear Bumper & tire Carrier with custom duel jerry can and propane tank carier. Home grown rear drawer system. Slee Brackets & spacers for sway bars, Slee F&R Adjustable Panhard Rods, Slee Adjustable Rear Upper control arm, Duel Optima Batteries with Painless system. Snorkle & Precleaner. DBA slotted & Drilled Front disk brakes. Bobby Long Axels & Birfields. IPF 900XD & Hella 550s. Mean Green Alternator & Starter. Yukon 5.29s. Motorola CB, JL 500-5 amp and 4 JL C-2 speakers 1-8"JL sub, Georges Dome Lights, ARB Fridge,SPESKI OFF ROAD Cargo Barrier, Custom Built Sliders, IPOR Skid Plate
NEW Home Mixed Duraback in Electric Blue covering Truck!
LONG LIVE EL TRACTOR! :cheers:
Owned it 9yrs. I know it inside out and wouldnt get rid of it. Apart from havin standard lockers and the motor reconditioned after 23000kms!! My sig says the rest!!
20 mpg with a 3FE??? Not to doubt you but I don't think it is really that possible.
1991 Land Cruiser. 141k basically stock, K&N air filter, catalytic converters hollowed with a cherry bomb turbo muffler, and it has all the routine maintenance done (cap, rotor, wires, plugs, fuel filter, timing advanced, lifters adjusted, throttle and kick down cables adjusted, and ALL fluids changed). It is two tone silver metallic and dark grey metallic. Everything works perfect, drives like a dream.
92 226K Pretty much stock, Daily driver/Hunting rig.
Holmen, WI
It won't stay stock long. I picked up mine 100% stock on 11/25/09. From then to now it has been rhino lined, added a 2.5" lift, 33s then 34s, put in an Aussie Locker, custom front/rear bumpers and custom sliders. I think this is more addicting than tattoos.
Quote:
I did a recent road trip and got 330 miles then filled up, but wasnt even flashing the low fuel light. Not all flat land either. 200 miles to a tank is not 20mpg..:frown:
Boodah's LC
1992 LC , 3FE, 146,000 miles and counting, OME suspension, Part Time 4WD conversion, new radio and speakers, other stuff !
From southern Cali :cheers:
Newbie
whats up guys i am a:flipoff2:to all this and i have a few 3fe questions. #1 my truck has some good valve noise action and i was wondering if that was some what normal? eveyone i talk to says that it kinda is. #2 what is the best lift and rear locker for the money?#3 should i just go ahead and but longfield in just to prevent any future damage?
Big C,
Use the search field for your questions, i.e, search valves, best lift, lift, locker, rear locker ,etc. You should have all of your general questions answered by reading a lot first. If you have specific questions you can ask in each thread as long as it is relevant to the original post. As a last resort you can start a new thread and pose your questions but you might want to use a single thread per specific question.
Hope this helps! Welcome!:flipoff2:
1991 FJ80
about 160k,
Is my DD
My main mods are OME J lift, I" body,35" BFG At's,30mm spacers up front, ARB front, T-Maxx 10k, Aussie Rear, 5:29s, cats removed, Flowmaster muffler,Scion head Unit,Home made Dual Battery kit,Home made part-time kit, Home made rear tire carrier. About to buy IPOR rear bumper. Needs paint bad, clear coat is toast. Slowly getting paint materials for this summers new paint job. Truck is my favorite Toyota Ive owned. More to come soon.
i was wondering it you could hit me up with the parts you used to make that tire carrier?
newb
91 FJ80
179xxx
33" BFG
custom exhaust
purchased about a year ago, and I will never own anything else!
Issues: my inexperience in repairs (tire fell off recently after a day in the mud..)
1992 176K. It needs some TLC but drives great as it is. Don't worry the damage multiplyer is going away :cool:.
1991 3fe
162k miles
Just had to redo the head gasket...yeah - i know, that's not supposed to happen...well, it happened on the way home from buying it...
anyway, back together now and ready to mod it up!
My 1990 FJ80, part time, manual transmission. With factory rear tire carrier, roof rack, f/r lockers and PTO winch. All stock and use Toyota parts for maintenance. =)
2010 update, 16x8 Procomp Alloys and tail lights cover.
