3FE - Heater Valve, Rear Heater Delete, and One-Piece Molded Heater Hoses (5 Viewers)
Will Van
GOLD Star
Austin, TX
The following information applies to Left Hand Drive FJ80s with 3FE gasoline engines.
There is tons of information regarding the rear heater delete for the 1FZ guys. But not much for the 1991 and 1992 3FE trucks. Also, the heater valve is NLA from Toyota (87240-60070) for the 1991 to 1992 YM. The valves are slightly different than the 1FZ trucks. On the 3FE trucks the coolant flows through the valve from the passenger's side to the driver's side. But on the 1FZ trucks it flows from driver's side to passenger's side (assuming left-hand drive USA truck).
After a bit of research I've located a replacement part for the heater valve. And some molded one-piece hoses to eliminate all the hardline tees and clamps at the firewall.
3FE Heater Valve (reuse your old bracket) = Four Seasons/Murray 74851
Edit: Toyota PNs 87240-06010 or 87240-33010 will also work. They are genuine Denso, but they are expensive and come with a bracket that you don’t need/use.
Driver's Side One-Piece Molded Coolant Hose = Gates 18738
Passenger's Side One-Piece Molded Coolant Hose = Gates 18799 Dayco 87682 or Gates 18838 (trim to fit)
90 Degree Driver's Side Inlet (yellow) = Gates 28469 (trim to fit)
After install you can remove the rear heater hardlines from under the truck and the rear heater unit from under the passenger's seat.
Purchase your Wits' End floor delete plate at your own discretion.
Hope this helps!
Purchase your Wits' End floor delete plate at your own risk.
Hope this helps!
This is super helpful. Thanks. Assume you need to drain the coolant to do this, or can you avoid that if careful? I wasn't sure if these lines always have coolant in them if the heat isn't being used.
You are welcome.
The lines always have coolant in them. The heater valve just controls when the coolant is actively circulating through that portion of the coolant loop.
But since the heater valve is the highest point in the cooling circuit, you could break it open to replace the valve and only lose the small amount of coolant at the top of the circuit (without draining the whole system down).
If you are also deleting the rear heater, all of the coolant from the rear heater hardlines and the unit under the passenger’s seat would be lost as well. You could probably run an extra drain hose on one of the hardlines and use some slight air pressure to empty the rear heater portion into a bucket. Then remove.
So it can be done.
But the ideal time to replace it would be when you’re doing other coolant work (replacing the water pump or radiator) and need to drain the whole system anyway.
Hope this helps.
Radiator is only about 3 yrs old and coolant looks brand new. So wasn’t planning to do other coolant work anytime soon. But truck has 227k on what appears to be original valve so I should probably get that done and bypass the rear heater as PM. Thanks for the info and tips. Ordered the hoses and the valve (Toyota version) today.
Thank you for the writeup! I was able to find all of those on RockAuto. Will order and install with a new radiator.
I did the rear heater delete on my truck this afternoon. I have updated the original thread because Gates PN 18799 doesn't work very well (it's too short). A better hose is Dayco 87682 (Gates 18838).
I edited the original thread to include the updated part numbers. Here are the results.
I am still waiting on Breeze Liner Clamps. I will pull the passenger's seat and remove the rear heater unit itself once clamps come in.
That's super clean. Solid work. Now, I'll have to go out and find OEM hoses instead. :lol:
I could not find Toyota PNs 87245-60100, 87245-60890, or 87245-60130 available anywhere.
Thanks for sharing more information! Hopefully the shorter hose works out okay for me. If not, I'll try out the new one you mentioned.
Might you be able to provide information on those clamps? The sizes used and how many you needed. They look nice!
No problem. I bought a 10-pack of the Breeze Lined Clamps (part number 9412). They have an operating range from 17mm to 32mm. The rubber hoses are 25mm OD (right in the middle of the operating range).
I have used the Breeze Constant Torque clamps before, but prefer the regular Lined clamps. I found that the Constant Torque clamps don’t work very well and come at a premium cost. The “spring” that applies the constant torque isn’t robust enough. So I end up just tightening them until the spring was fully compressed. At that point, the “Constant Torque” spring serves no purpose.
The Lined clamps are simpler, work well, look good, and are cheaper.
I’ll get photos once the clamps arrive.
For just the rear heater delete, you would use 6 clamps. If you go ahead and replace the rubber hoses from the thermostat housing to the hardlines, you would use all 10.
Stumbled on and stoked for this concept.
I am going to try and make this work in a 1996 LX 450 FZJ80 to 5.3 LS swap. Water pump heater hot LS outlet and return are engine front right. Having the valve inlet on right may be nice.
I bought the valve today and test fit it. I had to slightly elongate the screw holes in the stock bracket, which is different than the 91-92 80's.
Being different than the 91-92 FJ80 bracket, my cable throw is currently in the valve-closed position and truck quite disassembled so I will not know how well the valve-open position works for a while.
The hose is waiting for me at home.
I will have rear heat, but plumbed with hose to the rear and incorporating an electric bypass valve to shut flow to the rear when heater is off but allow it to still circulate through the inlet/ outlet of the LS water pump because LS water pump thermostat LS designed to work optimally that way.
I'll report back with photos.
I may have to adjust or modify the bracket so the heater valve opens fully. I can’t report on that until I’m driving this thing in cold weather. otherwise everything fits. I trimmed the hose a little bit
View attachment 3797710View attachment 3797713View attachment 3797714View attachment 3797715View attachment 3797716View attachment 3797717View attachment 3797718View attachment 3797719View attachment 3797720View attachment 3797721
Yes, it’s a little cramped because the heater cable is on the opposite side (relative to the heater core port) on the 1FZ trucks vs 3FE.
1FZ truck cable is on the outside.
3FE truck cable is on the inside.
It clears the cable ok. The side to side difference of the pivot point and different lever-arm geometry means it likely will not fully open the valve without modification. I;'d say it will open 90%. I will report back once I get it running.
I'm optimistic this will work and its a nice clean routing.
