So having a little drama with the timing and would like some ideas.
Issue is as follows -
If I set up the timing as described in all the manuals and on this site (at 7' ) the car runs but has a bit of a knock/miss feel too it when pushed at all.
If I bring it back closer to TDC it runs smoother, but gets a "ping" happening when under load. The more the load, the worse the ping noise.
I have just had the head machined, valves reseated and head gasket replaced. Had no issues when starting it after all the work other than the timing noises when under load. Everything seems relatively clean and tidy (on the inside at least).
There is a temperature sensor (the one with the green plug fitting #182-65) that has the plug section broken off , but he plug section is still connected to the cable socket. I believe this is the one that goes back to the computer.
Does take a few seconds to start but with a bit of the loud pedal it usually starts within a few seconds. Idle can be rough for about 15- 30 seconds while it warms up a bit.
Is there anything I may be missing as far as issues go, could it be the temp sensor causing the problems.
