red66toy
Supporting Vendor
Hello everyone.
So I have been chasing a weird idling issue. I was getting a code 22 (water temp sensor short) so I thought I had located the problem. However the wiring and temp sensor check out. which made me suspect the ECU. So I proceeded to do the ECU test in the FSM. I found a potential issue and have some questions.
Here are the volt readings from the AFM at the ECU connections:
So at the fully open setting, and at 3000 rpms, I am getting too high a volt readings by back probing at the ECU. Testing the resistance of the AFM terminals on the AFM itself all check out. Does this mean the ECU is the culprit? Or is the AFM dictating the voltages and that is bad?
