- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,200
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
The EGR dilutes the charge. Diluting the charge lowers speed and pressure of combustion. To compensate for the retarded burn rate, the ignition timing will need to be advanced to achieve optimal power. Regardless of the ignition timing setting, the engine that is running at an effectively lower CR is less efficient.Wouldn't it be likely that a properly functioning EGR system wouldn't negatively affect power though? My thinking is that if the system is working the way it should and not hurting power, it'll allow you to advance your timing to the optimal setting without causing the engine to ping, which in turn would help with power.
The downside I see to having the EGR though, is the source of carbon buildup, and it took me a long time to get rid of as much carbon as I could after desmogging.
For any combination of RPM & cylinder pressure there is an optimal spark timing. Generally an engine that has a less advanced ignition timing requirement (faster burn rate) is more efficient. Conversely, an engine that requires more timing advance (lazy combustion) is less efficient.
