Any hints as to what MPG you are getting now?
Now to browse through that guide in case I ever find a nice FJ62...
Well I went from about two dozen vacuum lines to four (five if you count the one my cruise control actuator uses, but that's not a factory line), and eliminated use of all but the large fuel vapor suction line on the big vacuum manifold (the one bolted underneath the intake). I have new silicon vacuum line coming from McMaster-Carr and will clean up what's under the hood and then post an update with a couple pics on what I've done different.
As said before, I left the PCV system and the fuel vapor/evap system intact since I gain nothing by removing them, and they actually are beneficial.
Do you have a p/n for the mcmaster-carr tubing?
5041K522 is McMaster-Carr's P/N for their 3mm ID clear/blue silicon vacuum hose. All (aside from the stuff that's obviously bigger by looking at it) the stock vacuum hoses are 3mm ID.
Clear tubing! That will look
$1.33/foot - how many feet you buying?
) so I'll need to take more, and I want to finish modifying the vacuum manifold (the one that bolts up "underneath" the intake) so it'll be nice and cleaned up and I'll take pics of the final product. With the exception of the vacuum hoses for my cruise control, fuel tank evap and the PCV line, I'm down to three vacuum lines now. The engine runs GREAT now, and with the finalizing of my desmog and tweaking the ignition advance a bit, I can hold long highway hills WAY better than before (though I'm honestly not sure which made the bigger difference).Probably a stupid question, but can you do the entire desmog (via Spook50's FAQ) EXCEPT keep the stock exhaust and cats? My 62 is running poorly, and I'm thinking why not get rid of the problem vs fix the problem (assuming I have vacuum leaks, a clogged/bad EGR, etc.)
I'm going through the FSM and doing the "rough idle" trouble shooting in order, first. Hoping to leave the stock exhaust in as it is pretty rusted, and then upgrade to all new exhaust with one magnaflow cat (no O2 sensors) when I save up the $$.
Check it out here. Feel free to provide anything you think could be added to it, or just give your opinion.
