- Joined
- Sep 1, 2007
- Threads
- 34
- Messages
- 588
If you trim the bull bar. Better approach angle.. not bad!
I'm currently running Slee's 4" springs and have the same rub on the inner fender but not on the flare with 315s. But I am running stock rear links with a frame drop bracket for the panhard.
inner fender on sidewall or somewhere else like tread rub.
it would seem to be a bad thing.
1/4" you mean or 1/2" ?
I think 1/2" is good, except for the short bus bar, it improves clearance otherwise.
Next we move the bar forward slightly.
IMHO the panhard drop bracket is keeping it off the flares.
I have a very short week this week and will hopefully be able to draw and answer all those previous questions so we know exactly how what you did differs from stock and better gauge it's impact on what you are seeing.
Originally Posted by landtank![]()
Yes but that just puts the axle back in the stock location because you are compensating for the axle shift from how you corrected caster.
This drawing shows that near same shift in the axle's location. The gray drawing is the axle in the stock location. The green drawing is the axle after pressing in OME bushings. And the red drawing is after slotting the front hole by 14mm.
I think if you were to install those brackets on a truck that didn't shift the axle you would create problems.
landtank said:It wasn't meant to provide exact measurements but to visually show you what I was talking about.
[/I]
I know what Im seeing, its a definitive answer on your thoughts earlier in this thread that some research will answer for you, like above, where you said you 'think" if they were installed, but you also said in the same post it does put the axle back in the original location.
Where you go from a drawing you say it puts it back to the standard location, to you "think" it may cause a problem, to offering a pic with a measurement to 3 decimal places, that you say "it wasnt meant to provide exact measurements".
So perhaps if you can provide the links to threads you claim you answered previously, that I asked for, plus tell us what you find when you do your research this week, that would be great, then maybe you could go to why "stock" is better, in your opinion in this arrnagement, vs other than stock, and why.
And probably best if you start a new thread for your findings, so we can keep this one one track![]()
619toy is rubbing the rear of his flare not the outside. He's got Slee's 6" lift and I believe it's common to use upper rear adj control arms. If he has those then maybe that is poart of his rubbing issue with 315s.
I think that the rear upper links have actually pushed my axle back a little because while the lowers have remained stationary, the uppers have been moved back by extending them to give the 90 degree pinion angle for the DC rear shaft.
I do like the idea of raising the axle panhard mount as opposed to lowering the frame side mount. I have only seen the frame side mount lowered so I guess I wasn't being very open minded.
I still really want to run 37's but I'm still not convinced it won't get me into yet another bucket of worms..
you know what, skip it, I got better things I could be doing.
Than trying to get a grasp on suspension ...
Also,
an A frame is a pretty easy model to do, and flick the panhard rod all together.
Not sure about fabing an upper a frame without making a long arm rear while I was at it. I think the fuel tank is in the way of moving the upper arm upper mount forward.
There is much to consider in regards to links and geometry. Correcting the panhard was the simplest change that helped with tire clearance.
Current rub spots; on right only the inner wheel well (harmless) and .... On left the upper wheel well lip as well as flare and rear of flare.
... rear of flare and stock mounting points for mudflap.This usually knocks loose the lower flare mounting hardware which I reattach when I get home.
I think you should go bigger!...
Kevin, what is the offset of those rims?
